Spark Plug gaps for a 351 Windsor
I removed my old sparkplugs from the block this past weekend while installing my new headers. I figured it would be good to install new ones. I forgot to ask the salesman what the gap should be for my size motor. Does anyone know what the gap should be? 0.040 may be?? Thanks for the suggestions and let the debate begin!
on a stock late model ignition its .044''. If you have a hotter coil it could be opened up more.
[Image: Outalne_017.gif]
Sparkchaser,
The motor is a 351 W form a 1972 Gran Torino. It has been bored .010 over with stock coil. Would a .044 gap be adequate?
sparkchaser Wrote:on a stock late model ignition its .044''. If you have a hotter coil it could be opened up more.
2x what he said:imwithstupid::hysterical:
a stock 71 cleveland was .040'' with points. I'd split the difference and go .042. Oh yeah old fords don't like expensive spark plugs.Don't spend much just stick with some autolites or something.
I got the Motorcrafts $2 each I think. What might be a good upgrade to a coil?
  Stainless/ Coated Headers needed- 1995 Bronco 351 Windsor .20 over trick flow heads jrshepherd 1 4,932 05-22-2018, 09:38 PM
  New Wiring for a 351 knoxville714 10 10,217 02-23-2017, 03:01 PM
Last Post: tcb3078
  '94 351 Rear Main replacement JayT 5 3,822 12-22-2012, 05:34 PM
  351 issues gumby93 18 11,129 09-29-2012, 07:30 PM
  Do vacuum lines plug in here? Ogeechee 4x4 3 2,655 09-28-2011, 06:33 PM
Last Post: markharrell
  1996 5.8L spark plug wires and coil jrshepherd 0 1,808 02-08-2011, 06:16 PM
  Spark Plug wire installation jrshepherd 2 2,932 12-19-2010, 12:13 PM
  Changing spark plugs 1996 5.8L jrshepherd 0 1,674 12-13-2010, 10:42 PM
  Torque Spec. Spark Plugs- 1974 302 v8 jrshepherd 4 3,816 01-24-2010, 12:47 PM
