1996 5.8L spark plug wires and coil
Hello. I'm having a hell of a time ordering these parts correctly from Summit Racing. I’m changed out the Napa OEM replacement stuff I bought a few months back, because the wires were not seating on the dist. cap correctly. I have ordered a MDS#8482 cap/rotor and MSD# 8227 coil. I have received two sets of plug wires to date. A set of ford racing that fit a old style coil and a motorcraft set that will not fit securely at the MDS coil. Does anyone have any suggestions? :banghead:
  1996 Ford Bronco- Body Bushing Install jrshepherd 2 4,533 09-19-2018, 02:50 PM
  1996 Bronco New BSD 4" long arm lift on IFS suspension- Setting Wheelbase jrshepherd 11 7,019 01-31-2016, 03:55 PM
  Popping fuses and melting wires Bitch'nBronco 27 12,396 08-02-2014, 10:55 PM
  Do vacuum lines plug in here? Ogeechee 4x4 3 2,669 09-28-2011, 06:33 PM
Last Post: markharrell
  1996 5.8 L Engine Rebuild- Cylinder heads jrshepherd 0 3,428 07-17-2011, 11:13 AM
  Engine Rebuild. 1996 5.8 L jrshepherd 0 1,745 05-05-2011, 02:02 AM
  Spark Plug gaps for a 351 Windsor Crawdad 5 6,777 01-04-2011, 04:57 PM
  PCV Grommet 1996 5.8L jrshepherd 5 3,886 01-03-2011, 11:14 PM
  Spark Plug wire installation jrshepherd 2 2,943 12-19-2010, 12:13 PM
  Changing spark plugs 1996 5.8L jrshepherd 0 1,678 12-13-2010, 10:42 PM
