TRO install on my '77
After mutilating my tie-rod at URE last Nov I decided to step things up a notch and install a heavy tie rod over conversion courtesy of Complete Off Road's universal kit http://completeoffroad.com/i-124127-tie-...nd-60.html
We placed the front axe on stands and removed the tires, tie rod, and drag link.
Next we had to use the reamer to ream the knuckles to accept the larger tie rod ends from the top. It went pretty quick but be careful to keep your angle correct or it can get out of control in a hurry and you will end up with a misaligned hole.
Next we had to come up with an easy way to ensure we had the knuckles aligned correctly so we could measure to cut the tie rod tube to length. Luckily we had my beadlocks sitting around so we slaved them on and measured the rims front and rear until they were about 1/8" toe in. We locked them in place with a cargo strap and measured and cut the tie rod tube. Once cut, we tacked the inserts into place and slaved the setup.
Next we started on the drag link. We centered out the steering box and reamed out the passenger tie rod link so it could receive the tie rod end of the drag link. This is necessary because it comes with a small hole so you can choose to set it up from the front or the rear. Once the drag link tube was cut, we tacked the inserts into place and slaved the setup.
We immediately ran into an issue with the tie rod hitting the lower trac bar bolt and nut while turning. This severely limited the steering range. Considering there is a need to parallel the trac bar and drag link to eliminate bump steer, a trac bar riser would be ideal considering my 5.5" lift. Unfortunately, my heavy duty Duff's lower coil cups will not allow installation of the riser without severe cutting and modification it. We decided to replace my drop pitman arm with a stock arm instead in order to fix the geometry and we used a reciprocating saw to cut part of the lower trac bar nut and mounting bolt to clear the tie rod and allow full motion.
Everything was welded up and painted and off I went.
Pending installation of a stock pitman arm, this installation was pretty simple and straight forward. I will let you know how the pitman arm works out for the alignment once I get it.
[Image: P1020705.jpg]
[Image: P1020706.jpg]
wow. keep an eye on that trac bar nut!! Looks good so far. Should be about perfect with that stock pitman arm back on it.
There is more meat on the bolt than the picture seems to depict. We also drilled it and installed a cotter pin. Since it is a shear load on the bolt, the nut does not really take any force so I had no qualms about removing a good chunk.
hells yeah, hot dayum...ROCKS...[SIZE="5"]HERE WE COME!!![/SIZE]Confusedmokin:
I think we have a Gulches trip brewing in our near future.
chuzie Wrote:I think we have a Gulches trip brewing in our near future.
sounds good here!!
yeah, it almost looked like the nut was the same thickness as the washer behind it... cool deal.
Well let's just say that some people have trouble drilling a straight hole while other have issues cutting a straight line. :toothy12::toothy12::toothy12::toothy12:
So the stock pitman arm seemed to have worked to correct the large disparity between the trac bar and the drag link. The
The trac bar is at about 15 degrees and the drag link is at almost 10 so they are almost parallel. The only way I see to really make them perfectally parallel is maybe to heat up the pitman arm and bend it up slightly to raise the end of the drag link. There is not much room to work with since it is sitting just under the frame and it will interfere if I go too far. There is still a slight amount of bump steer but not enough to worry about. If I get bored I will see about perfecting it.
[Image: P1020805.jpg]
Looks Stout!:biggthumpup:
nice work chuzie...
  1996 Ford Bronco- Body Bushing Install jrshepherd 2 4,551 09-19-2018, 02:50 PM
  Southern Rods AC kit install..part 1-heater blazinchuck 22 12,536 03-09-2013, 09:47 PM
  ebay radiator(5.0 conversion) install... blazinchuck 8 8,076 10-15-2012, 10:30 PM
  bushing install ? firefighter2134 2 4,145 08-11-2011, 10:30 PM
  Oil Pressure Guage install location??? Crawdad 3 3,534 04-12-2011, 12:35 PM
  ididit install berg bronco 25 10,127 12-27-2010, 01:09 PM
Last Post: berg bronco
  Need help with transfer case install 73Bronc 34 17,088 08-18-2010, 11:45 PM
Last Post: 73Bronc
  Need Speaker Install Ideas 73Bronc 20 9,932 03-19-2010, 09:00 PM
  HELP INSTALL POWER STEERING PBONE2000 3 2,841 12-11-2009, 01:08 PM
  Mini Starter install jrshepherd 2 2,364 11-23-2009, 08:30 PM
