Mini Starter install
Hello. I'm installing a Mini Starter From Jeff's. There was not one when purchased from PO. I understand it received power from the starter solenoids, but what triggers the solenoids on the starter. I had it tested and everything is ok. Any suggestions? Confusedcratchhe:
On the old style starter there is no solenoid on the starter the relay near the battery does that. It sounds like you need a jumper wire from the START side of the relay (other side from the battery) to activate the solenoid on the mini starter. The Positive on the starter can hook to the Battery side of the relay up top.
http://www.mustang50magazine.com/techart...index.html
http://i50.photobucket.com/albums/f315/T...elay-1.jpg
http://www.stangnet.com/mustang-forums/7...stion.html
Thanks for the tip. I ended up jumping it from the main power from the starter to the solenoid.
Thanks again.
  1996 Ford Bronco- Body Bushing Install jrshepherd 2 4,568 09-19-2018, 02:50 PM
  Southern Rods AC kit install..part 1-heater blazinchuck 22 12,586 03-09-2013, 09:47 PM
  ebay radiator(5.0 conversion) install... blazinchuck 8 8,099 10-15-2012, 10:30 PM
  bushing install ? firefighter2134 2 4,155 08-11-2011, 10:30 PM
  Oil Pressure Guage install location??? Crawdad 3 3,550 04-12-2011, 12:35 PM
  TRO install on my '77 chuzie 9 5,959 12-28-2010, 06:41 PM
  ididit install berg bronco 25 10,189 12-27-2010, 01:09 PM
Last Post: berg bronco
  Need help with transfer case install 73Bronc 34 17,131 08-18-2010, 11:45 PM
Last Post: 73Bronc
  Need Speaker Install Ideas 73Bronc 20 9,961 03-19-2010, 09:00 PM
  HELP INSTALL POWER STEERING PBONE2000 3 2,849 12-11-2009, 01:08 PM
Users browsing this thread:
