79 F150 Dana 44 Axle Question
We just pulled our 79 Dana 44 apart last night and found a couple of problems. This will be a street, trail, and beach truck, no heavy wheeling.
Driver side outer axle - the splines are a little screwed up from the snap ring out, is this a problem?
Passenger side outer axle - the smooth part of the axle next to the splines has a few grooves. These grooves are about 1/4" in width, smooth, but not that deep, is this a problem?
Thanks
pass side, i'd run it.
driver side, probably be ok no harder then you plan on pushing it.
Broncomania,
Would you or know of anyone in the area which may have a extra outer axle (stock ford)? I don't like the pass. side one and since we are rebuilding the axle from end to end i think i would like to replace it.
Thanks, John
2000F150SAS Wrote:Broncomania,
Thanks, John
not right now .
  Steering shaft Extension Question??? Broncitis 4 4,649 04-17-2015, 02:27 PM
  Exhaust question Casey835 27 14,921 08-16-2013, 06:03 PM
  Axle Tube Vents Casey835 4 3,563 03-01-2013, 08:20 PM
Last Post: Casey835
  ***9" Axle Gurus...Ring gear dug into pilot housing!** chuzie 7 5,061 12-05-2012, 12:35 AM
  dana 44 mods 64500xl 8 4,028 07-06-2012, 08:44 PM
  Axle / Gear gurus help!! SC74 4 4,115 03-28-2012, 08:52 AM
  1991 351W EFI Question Crawdad 4 3,877 03-27-2012, 09:05 AM
  F150 axle shaft tech blazinchuck 12 6,638 12-03-2011, 09:34 PM
  Hard top Question 744x4 5 6,158 09-06-2011, 10:32 PM
Last Post: Mill Knob
  Tire question dixieboyz13 12 7,798 08-25-2011, 01:58 PM
Last Post: ncsubronc
