Tranny took a dump on me :(
Yep, that's right folks. I guess the work dump may be a bit dramatic. I noticed that the truck seems to bog down starting from a stop and feels like it is stuck between 1st and 2nd. I have to either bump the throttle or manually shift to get it to slide into 1st. It is intermittent, not associated with temperature, and happens about 50% of the time. The fluid level was fine but I found it to be dark and may possibly burned. No major metal chunks, flakes, etc; just has the typical clutch material in the bottom of the pan.
I pulled the valve body apart and am cleaning it up which I did not do when I rebuilt it 2 years ago. Whoops! I also need to pull the governor off and clean that good as well, but I need to remove the transfer case to do that Sad
I am missing the pump screen (larger finger sized screen). If anyone has one, I would appreciate it.
More to come.
you mean the pickup tube that goes to the filter? i might have one. will have to check. is it a stock type filter/trans pan? hope you get it fixed!
maybe it is just a bad vacuum modulator. did you try a new one?
Vac mod is good. This is a finger sized metal screen that goes into one of the passages on the tranny housing before you install the valve body. I got back on the road at midnight but she was acting weird in Drive like the band was not engaging at all. When I shift manually, I get all three gears. More to come....
Have I ever mentioned that I HATE transmission fluid!!!
Getting burned out so I hope I get it fixed today. The Bronco and I need some time apart.
  C4 tranny hurtin DirtyWhiteBoy 12 6,520 03-20-2013, 08:36 PM
Last Post: DirtyWhiteBoy
  Leaky tranny dip stick tube. chuzie 4 2,860 08-10-2008, 09:16 PM
  Ideas for C4 tranny upgrade options chuzie 14 6,996 06-26-2008, 08:38 AM
  C-4 tranny rebuild NC-Fordguy 4 5,270 12-07-2007, 02:48 PM
  My T-day Transfer case TRANNY project johnpaulgolf 3 2,638 11-26-2007, 07:30 PM
