C-4 tranny rebuild
Was wondering which kit you all have used.
Last rebuild lasted two years maybee 15k miles. I'm hoping this time around I have better luck
Been looking at summit and jegs
1974, 331 stroker, Holley TA,Dana20 twin stick w/terra low gears, 456 axle gears, detroit in the rear, true track up front ,MSD ignition, 37x12.50 PJs, 9k warn-tabor
I prefer to buy all my parts myself. The kits are a little overpriced. Are you looking to build it yourself or take it to someone?
I'll rebuild it myself
Shops around here are quoting 5 bills or so and offer a 90 day warranty
I can get it to last longer than that
I usually buy all my parts from a local transmission supply in Kannapolis. I get the overhaul kit with all the metal clad seals, gaskets, and O-rings. Then I buy my bands, clutches and steels individually, filter and modulator for each application. A sprag is also cheap insurance. I like to use 5 forward and 5 direct Alto Red clutches with Kolene steels. I also prefer to use a Kevlar intermediate band. When I build the valve body I add a "shift kit" to make quick firm shifts. The pump needs a simple modification to help with oil flow to the cooler. The case needs the return passage enlarged and the #9 bushing need to be drilled for better oiling.
I like tinkering with C4s. I have a C6 with a 203/205 that I need to build to go in my rig. My C4 has served me very reliably and makes me hesitant about swapping it out.
my c4 works great. it has all performance automatic internals and bucketobolts did a killer job on the assembly. thanks again.
  1977 Ford Bronco rear ended 9" rebuild Crawdad 10 9,161 01-19-2017, 12:53 PM
  C4 tranny hurtin DirtyWhiteBoy 12 6,592 03-20-2013, 08:36 PM
Last Post: DirtyWhiteBoy
  Tranny took a dump on me :( chuzie 2 3,132 09-05-2011, 09:12 AM
  1996 5.8 L Engine Rebuild- Cylinder heads jrshepherd 0 3,439 07-17-2011, 11:13 AM
  Engine Rebuild. 1996 5.8 L jrshepherd 0 1,753 05-05-2011, 02:02 AM
  Heater Rebuild and Upgrade scbronco 16 7,483 12-24-2010, 11:02 AM
  Stock 66 interior rebuild thread 66stocker 37 19,478 04-03-2010, 11:07 AM
Last Post: 66stocker
  Leaky tranny dip stick tube. chuzie 4 2,888 08-10-2008, 09:16 PM
  Ideas for C4 tranny upgrade options chuzie 14 7,042 06-26-2008, 08:38 AM
  My T-day Transfer case TRANNY project johnpaulgolf 3 2,668 11-26-2007, 07:30 PM
