USA Standard Gear?
I wouldn't be asking this question IF Yukon carried a 5:13 R&P for a D60 HP, but they don't.
Does anybody have experience with the USA Standard gears. I know that they are not machined as much and may have a little noise, but this will be in the front. I have a Precision R&P in the rear already.
Anybody have pros or cons?
i've installed a few sets. they aren't great, but should work fine.
run what you can get bubba....im surprised yukon dont have that. back in the K5 days i got yukon 5.13's for the 10blts. if you go with the brand 4wheel parts sell...they had a warranty that covered anything(even being set up wrong)
  cummins to a ford small block standard trans adapter plate Rdnckdemo 2 2,504 04-14-2013, 01:19 AM
Last Post: Rdnckdemo
  ***9" Axle Gurus...Ring gear dug into pilot housing!** chuzie 7 5,063 12-05-2012, 12:35 AM
  Axle / Gear gurus help!! SC74 4 4,119 03-28-2012, 08:52 AM
  Chain Drive vs. Gear Drive BucknEB 6 4,633 03-10-2011, 04:22 PM
  Precision Gear vs Yukon? JayT 15 8,256 10-26-2009, 09:30 AM
  Determine gear ratio chuzie 17 12,489 07-13-2009, 10:15 PM
  Gear Ratio??? BroncJr 9 7,492 03-31-2008, 08:17 PM
  Gear Reduction Starter johnpaulgolf 4 4,282 02-28-2008, 04:03 AM
