Axle / Gear gurus help!!
I'm finally ready to buy my gears and lockers for the crawler but have one problem before ordering.
I bought a used d60 5:13 r&p that I can't figure out what it is so I can't order the right carrier for what axle?
It is a Precision Gear and the ring gear is stamped 60D 513 R. The pinion is stamped 60D 513 P. My first assumtion was that R meant RING and P meant Pinion - but that would be too easy and it does not. I have contacted Precision 3 times and finally got someone today who actually cared and tried to help.
Here's my problem... the R means REVERSE which would work for my front HP 60, but every tech article I read says that the gears should rotate counter clockwise for a reverse ring gear (and vice versa for a standard cut)- mine are clockwise (like a standard cut) Confusedcratchhe: Precision swears that the R is REVERSE and that it doesn't matter which way the spiral is.
When I got home I pulled my front diff cover and sure enough the stock ring gear is counter clockwise making me believe that the R does not mean Reverse. They say that the P on the pinion means "Pro series" which is for drag racing applications. In the front that would be good, but not so sure for the rear Confusedcratchhe:
I'm tempted to buy both r&p's now and scratch this one I have, but then again it's an expensive set that I'd love to take advantage of and not have to buy another. IF it will work in the rear, I wonder what carrier size to get. Precision says a 4.10 and down, but I can't rely on their info much now.
Here are a few pics of the ring gear and the stock one in the front diff now.
PM sent
I did some archiving. That set came out of a rear axle. No idea why it is labelled as reverse. Also, it had a 4 series Detroit bolted to it. So, it should work in your rear axle with a 4 series carrier (non-thick). I was told it was a Ford D60 out of an F250. The front was a HP44 axle.
Thanks for taking the time to go back and look Bart.
4 series carrier - 4.10 and numerically down carrier? That is what PG is saying and their site says, but that would mean it is a thick gear, right?
On the way out the door this morning I measured the ring gear in my front housing.
It measures 1" and the Precision ring gear I have is 1-1/4". How would the thick gear fit in the smaller carrier like what I have in my stock set now?
  Axle Tube Vents Casey835 4 3,569 03-01-2013, 08:20 PM
Last Post: Casey835
  ***9" Axle Gurus...Ring gear dug into pilot housing!** chuzie 7 5,069 12-05-2012, 12:35 AM
  USA Standard Gear? SC74 2 2,589 03-09-2012, 09:51 PM
  F150 axle shaft tech blazinchuck 12 6,646 12-03-2011, 09:34 PM
  Stuck rear axle? (9") Action 6 4,535 06-24-2011, 09:42 PM
  Chain Drive vs. Gear Drive BucknEB 6 4,638 03-10-2011, 04:22 PM
  rear axle shims? berg bronco 15 6,091 01-04-2011, 09:52 PM
  axle bluebooger 6 3,413 12-02-2010, 12:45 AM
  Axle Seal Leak.. Again! 73Bronc 13 7,051 10-15-2010, 01:50 PM
  79 F150 Dana 44 Axle Question 2000F150SAS 3 4,292 01-31-2010, 03:53 AM
