'94 351 Rear Main replacement
Here's a dumb question... To replace the rear main on a '94 351 (Bronco)... Do I need to pull motor/trans? e.g., is it one-piece or two?
94 should be 1 piece. You'll need to pull the trans off. You might be able to do with without taking the oil pan off and removing the rear main cap, but can't say for sure. I do them on the engine stand, all apart, when I do them.
Chit. I thought/feared so... Thanks, Bartholomew...
How much would someone charge (hours or $), you think?
That I have no idea on. Call around and let us know what you find. How bad is it leaking?
I wonder what the book says... I'd imagine it has to be a long job... I'm not sure how bad it is yet... I just " acquired" this one... But once I'm done with the trans/axles on the k5... I'm not feeling another" big" job... Got save up some time/energy to get bus back mobile again...
  Stainless/ Coated Headers needed- 1995 Bronco 351 Windsor .20 over trick flow heads jrshepherd 1 4,936 05-22-2018, 09:38 PM
  New Wiring for a 351 knoxville714 10 10,222 02-23-2017, 03:01 PM
Last Post: tcb3078
  1977 Ford Bronco rear ended 9" rebuild Crawdad 10 9,059 01-19-2017, 12:53 PM
  Rebuilding used rear leaf springs Crawdad 5 6,517 12-12-2016, 11:54 AM
  Lighted rear view mirror chuzie 6 7,720 06-20-2015, 12:18 AM
  Another Bronco Floor Replacement jdowns67 83 32,737 12-20-2014, 11:33 AM
  rear main seal snipes243 5 5,043 05-03-2014, 11:45 AM
  stock rear drums scbronco 11 5,837 03-06-2014, 08:09 PM
  Late 70s Cadi rear disc brakes for 77 banjo rear end Crawdad 11 7,605 01-11-2014, 12:26 AM
  77 EB Rear Drive Shaft Dropped - Second time in six months UTFLIWGYA 4 4,150 12-01-2013, 10:38 PM
