Fuel Odor
I've recently replaced my old carb due to a fuel leak but I continue to smell a strong fuel odor from my Bronco. I'm not able to find a visible leak in the fuel line. Could this be a vent leak? If yes, does anyone have advice on the best way to locate and fix? Thanks, Trey
Is it dual tank, glass hatch open/closed, any holes in the floor, where do exhaust tips exit?
are you sure it's fuel or exhaust?
It was a dual tank initially but I've removed the smaller auxiliary tank and gone with a higher capacity tank in the rear. When I added the new rear tank I had to cut my exhaust pipes so they actually exit under the bronco at this point. This obviously adds to the exhaust odor while driving but it's not too bad. The floor has been restored but there could be a few holes in seams underneath. The odor is most noticeable when the engine is turned off and the bronco is closed up in the garage.
I think I may have found the source. The old auxiliary fuel lines are plugged but there appears to be some leaking around the end points. I think I may try removing the lines completely and plugging the auxiliary fuel tank ports directly.
  In-tank fuel Pumps snipes243 0 2,359 06-22-2015, 02:06 PM
  Efi and stock fuel tank snipes243 3 2,972 12-11-2012, 03:28 PM
Last Post: Carolinaoffroad
  fuel line leak firefighter2134 5 3,290 03-12-2010, 06:46 PM
  Fuel line jrshepherd 2 3,126 12-11-2009, 01:07 PM
  Fuel leaking at cap LOTS OF PRESSURE!!! chuzie 21 10,659 07-13-2009, 08:55 AM
  1990 Fuel Pressure??? 2000F150SAS 2 2,826 07-06-2009, 10:38 AM
Last Post: 2000F150SAS
  EFI Fuel Pump Question SC74 2 2,650 07-11-2008, 10:30 AM
  fuel filler hose? Mark's89 6 5,644 04-06-2008, 05:08 PM
Last Post: Mark's89
  Fuel injected or Carb obxbronco 12 8,365 02-20-2008, 07:55 AM
Last Post: obxbronco
