CO2 tank and air compressor
So i want to use CO2 as my primary air source but not be stranded without air when i need it the most.
Can i route my a/c compressor to the CO2 tank for a backup in the event i deplete my CO2?
Sent from my SAMSUNG-S3 using Tapatalk 2 on CyanogenMod
i wouldnt...and i dont think you can. the c02 is liquid filled. i wouldnt worry about a tank if thats the case...i used my OBA with out a tank(straight off the compressor) and it aired the tires just fine.
Why?
i ask you why...after ive said what ive said????
U said u think and gave no valid justification. I was looking for a helpful answer. No a shot in the dark guess.
Didn't ask if i needed a tank. Read the question again bro and then ask YOURSELF why.
:banghead:
so let me see...you want a c02 that is liquid filled, then when its empty , you want to fill it with compressed air....NO
Again, why?
listen pecker head!
1. you dont need it!! compressor works just fine without tank
2. the c02 tank will have gauges/regulators...and is a liquid filled tank
if your so anal...then add a separate tank just for oba....again, you dont need it. doubt your gonna run through the c02 in a weekend.
that being said...maybe if you ever did a hell week would the back up plan might be needed.
I want air tools. U r right, for tires, i will never empty co2 in a weekend.
As for hell week, fyc!
U don't own air tools! Fyc...wrenches still work if your not a pu**y
Sent using my HTC ONE via Tapatalk
  DIY Gas Tank? knoxville714 3 5,524 06-22-2016, 11:30 AM
  ARB compressor electrical connector snipes243 3 4,476 12-04-2015, 01:48 PM
  23 gallon tank snipes243 13 6,323 06-26-2015, 07:00 PM
  In-tank fuel Pumps snipes243 0 2,342 06-22-2015, 02:06 PM
  Cleaning an old gas tank wepuckett 11 11,651 09-11-2014, 09:44 PM
  Efi and stock fuel tank snipes243 3 2,948 12-11-2012, 03:28 PM
Last Post: Carolinaoffroad
  Question: Trans lines and Gas tank jrshepherd 0 2,441 08-24-2009, 10:22 PM
  Surfs rust in gas tank. HELP!!! Mill Knob 5 5,985 04-09-2009, 12:59 PM
Last Post: Mill Knob
  Gas tank berg bronco 3 3,046 11-13-2008, 10:44 PM
  Removing Aux Tank Straps??? High Pressure 2 3,728 05-10-2008, 10:07 PM
Last Post: High Pressure
