23 gallon tank
So Im looking at getting a bigger tank and fixing my possible fuel pump problem. Does any have any experience with the sherman/BC broncos EFI tank?
have one installed in mine with the in-tank fuel pump. No problems so far over the past 5-6 years. I also have their skidplate installed.
Nick
'73 Bronco - trail modified
Nick with your 2" body lift does it hang about the same as the stock tank?
i think its a great fit with a 2" body, i only have a 1" body...wish my tank was higher, but im building a skid plate for it. i atcuallu got WH's to hook me up with a better deal than BC. and they get there tanks from bc...go figure. i got the tank ready to drop in, bc will send the pump for you to install. go WH!
I got that tank for my 76. Worked really well, so much I kept it but later traded it. Installs so easily. I plan to go back and get another one when the time comes. I sorta wish wish someone would build up a SS or Aluminum one that is adjustable like Chucks tank. I like the way it can adjust from 0"-2" body lift.
snipes243 Wrote:Nick with your 2" body lift does it hang about the same as the stock tank?
It is real close to a stock looking tank with the body lift. I do think a skidplate is needed, you can see several scratches in my skidplate that probably would have been a good sized dent in the tank.
Nick
So moral of the story if you go 23 gallon tank 2 in body lift recomended and skid plate?
Sounds good I will probably get one. WH has a wait list right now for theirs and as usual im waiting for BC Broncos to get back to me on shipping price.
Nick you wold happen to have a picture of the skid plate? Is it worth the $160 or is easy to make
wepuckett Wrote:So moral of the story if you go 23 gallon tank 2 in body lift recomended and skid plate?
2" recommended = not necessarily, I would say for a trail rig you don't want it hanging down any more than a stock tank, therefore a 2" lift is ideal. Street rig - it doesn't make a difference if it hangs down a little lower, it is just cosmetic.
skid plate = again, your choice - I like to wheel in the rocks and I'm not extremely careful with where I drive sometimes and not having to worry about putting a hole in my fuel tank is worth having the skid plate.
snipes243 Wrote:Sounds good I will probably get one. WH has a wait list right now for theirs and as usual im waiting for BC Broncos to get back to me on shipping price.
It is probably easy to make, just bent steel with a couple of mounting tabs. I don't have any pictures, but here is a link to BC broncos site, they have a pic on there
http://www.bcbroncos.com/store/product_i...ucts_id=94
  DIY Gas Tank? knoxville714 3 5,522 06-22-2016, 11:30 AM
  In-tank fuel Pumps snipes243 0 2,340 06-22-2015, 02:06 PM
  Cleaning an old gas tank wepuckett 11 11,650 09-11-2014, 09:44 PM
  CO2 tank and air compressor chuzie 14 6,633 10-18-2013, 08:01 PM
  Efi and stock fuel tank snipes243 3 2,948 12-11-2012, 03:28 PM
Last Post: Carolinaoffroad
  Question: Trans lines and Gas tank jrshepherd 0 2,441 08-24-2009, 10:22 PM
  Surfs rust in gas tank. HELP!!! Mill Knob 5 5,982 04-09-2009, 12:59 PM
Last Post: Mill Knob
  Gas tank berg bronco 3 3,042 11-13-2008, 10:44 PM
  Removing Aux Tank Straps??? High Pressure 2 3,728 05-10-2008, 10:07 PM
Last Post: High Pressure
