Question: Trans lines and Gas tank
Hello. I am bring back to life a 74 bronco. I ordered SS trans cooler lines from Jeff's. It will not attach to the C4. Does anyone know what type of adapters to use? What type of trans cooling systems do you all use? I need a rear gas tank because mine is rusty. I thought about restoring the one with a Summit kit? What are your thoughts. I do not want to run the side/aux tank. Thanks for all of your help.
JohnConfusedcratchhe:
  DIY Gas Tank? knoxville714 3 5,518 06-22-2016, 11:30 AM
  gas gauge help snipes243 9 8,930 09-14-2015, 10:41 AM
  23 gallon tank snipes243 13 6,309 06-26-2015, 07:00 PM
  In-tank fuel Pumps snipes243 0 2,333 06-22-2015, 02:06 PM
  Steering shaft Extension Question??? Broncitis 4 4,655 04-17-2015, 02:27 PM
  Cleaning an old gas tank wepuckett 11 11,640 09-11-2014, 09:44 PM
  Automatic Trans: Why does the engine die as soon as I put it in Park or Neutral???? UTFLIWGYA 6 6,080 05-15-2014, 11:50 AM
Last Post: rbodine
  CO2 tank and air compressor chuzie 14 6,612 10-18-2013, 08:01 PM
  Exhaust question Casey835 27 14,934 08-16-2013, 06:03 PM
  cummins to a ford small block standard trans adapter plate Rdnckdemo 2 2,504 04-14-2013, 01:19 AM
Last Post: Rdnckdemo
