Removing Aux Tank Straps???
Okay I have removed my auxiliary polly fuel tank from my '77.. I'm left with the (2) tank straps that are attached behind the front drivers side wheel. Other than "cutting" them is there a way to remove without damaging them?
'77 EB, 2.5" SL, 2"BL, Cummins 4bt, C4 w/Art Carr manual Valve Body, 35" BFG KM2s
http://www.youtube.com/watch?v=M_HqhiW38ik
I believe there is a bracket that holds those in. I was able to remove everything on the aux. tank with out cutting anything. I dont think the aux tank on a 77 is different than anyothers, except the rear tank. Good luck,Chuck
blazinchuck Wrote:I believe there is a bracket that holds those in. I was able to remove everything on the aux. tank with out cutting anything. I dont think the aux tank on a 77 is different than anyothers, except the rear tank. Good luck,Chuck
Finally removed the straps today and installed the auxillary tank that I got from from BroncoWard. Thanks for the advice, removed the 4 bolts & bracket and the straps were loose...
  DIY Gas Tank? knoxville714 3 5,518 06-22-2016, 11:30 AM
  Removing the Tub ParadisePWoffrD 4 5,480 10-08-2015, 06:22 PM
  23 gallon tank snipes243 13 6,309 06-26-2015, 07:00 PM
  In-tank fuel Pumps snipes243 0 2,334 06-22-2015, 02:06 PM
  Cleaning an old gas tank wepuckett 11 11,640 09-11-2014, 09:44 PM
  CO2 tank and air compressor chuzie 14 6,612 10-18-2013, 08:01 PM
  Efi and stock fuel tank snipes243 3 2,944 12-11-2012, 03:28 PM
Last Post: Carolinaoffroad
  Question: Trans lines and Gas tank jrshepherd 0 2,436 08-24-2009, 10:22 PM
  Surfs rust in gas tank. HELP!!! Mill Knob 5 5,975 04-09-2009, 12:59 PM
Last Post: Mill Knob
  Gas tank berg bronco 3 3,032 11-13-2008, 10:44 PM
