Carburetor and intake manifold 1974-302-auto
I have a Bronco that has been sitting for some time when purchased. I tried to rebuild the origional 2bbl, but it still seems off. Because money is tight I would like to try another rebuild before money is spend on the upgrade (4bbl). Would anyone in the Charlotte area who knows more than me like to help me successfully rebuild the carb? Thanks. Shep
What type of 4bbl set up are u guys running (302 v8 c4 auto)? I may have to pony up for a new set up. The 2bbl is driving me nuts? Thanks Shep
i had a 86 mustang HO 4bbl intake with a holley truck avenger 670...worked great, however, JP's elebrock carb with off road kit seemed better
Keep in mind 1 good backfire through the carb can take out the power valve. Also, not all rebuild kits are created equal. When you have it apart, soak your jets, and everything else you can.
OR- This could be something as simple as a vacuum leak, crack in the manifold spacer, etc.
blazinchuck Wrote:i had a 86 mustang HO 4bbl intake with a holley truck avenger 670...worked great, however, JP's elebrock carb with off road kit seemed better
Yes I have been very VERY proud of my edelbrock w/ the offroad kit in it ... they make one already set up for off road conditions ... I did not buy that one and added the offroad kit ... I can't seem to think of the name ... but I would go with the offroad carb from edelbrock for sure :biggthumpup:
Edelbrock "Thunder" series Confusedmokin: ... google is my buddy :hysterical: ... hehehe
Thanks for all of the great info. You all have been a big help. The carb is apart and soaking. I did not clean it well enough the first time, so I will see if this works. It seemed to be missing. I have changed the plugs, wires, points to HEI and cap/rotor. I will post an update hopefully soon. Thanks again. Shep
I got the carb rebuilt (It only took two tries) and she is sounding sweet. Thanks again for all of your help.
  Manual to Auto swap and Auto to manual swap wepuckett 1 2,932 07-24-2014, 03:26 PM
  who's running 302-4r70w-zf-d20 j shift-twin sticks? chuzie 2 2,359 12-11-2011, 10:14 PM
  1973 Bronco 302 mcgyver 6 4,228 01-30-2011, 10:58 PM
  Need a carburetor hankster 5 3,218 01-10-2011, 08:57 AM
  water pump v8 302 torque spec jrshepherd 5 5,176 11-13-2010, 10:45 PM
Last Post: Casey835
  Torque Spec. Spark Plugs- 1974 302 v8 jrshepherd 4 3,846 01-24-2010, 12:47 PM
  Thinking about swapping my 351W for a 302 cavscout 8 4,344 10-22-2009, 08:02 AM
  BII 302 Swap BroncJr 27 19,715 04-27-2009, 11:39 PM
Last Post: Mtrhd0024
  302 EFI conversion blazinchuck 30 11,389 04-17-2009, 09:24 AM
Last Post: Bighorn
  289 intake seanrook 17 10,250 10-31-2008, 07:42 AM
Last Post: seanrook
