front axle vent
Now that i need this i can't find who sells them.. The piece that threads into the d44 case that hold the brake block and the vent line hooks to. Where can i find one. Ken:banghead:
that should be easy find on any old 9" or D44 axles(junk yards)...I might even have one. I let ya know Ken,Chuck
If chuck doesn't i probably do. i'll look when it gets daylight.
Thanks. dont know what happen to mine, po used a solid bolt.ken
I think national parts depot sells them for about $10. Check out their online catalog.
http://npd.dirxion.com/Main.asp
Bill
Thanks, Ole bronco buddy Tim has graciously donated one. Just for info i did find that wildhorses has em $12.
Ken
Run a # 31 bit down the center hole to get the crud out of it so it functions properly.I had a leaky 9 for a long time and found out the vent was clogged making it build pressure and the axle seals would leak.20 seconds with the bit fixed it right up.Now I do this to every axle I rebuild and you wouldnt believe the crud that comes out of them.
03 Honda Shadow Spirit
It was clean when I sent it to him. Inside and out.
Tim
74 Bronco Ranger halfcab
w/toys
  Front axle krazybronco 1 1,765 02-20-2011, 11:44 PM
  Stiff front end. Rollers888 14 5,876 01-31-2011, 03:27 PM
Last Post: Rollers888
  RockSolid PreRunner Front Winch Bumper 92-96 Sweat 28 17,384 06-02-2010, 06:51 PM
  Cronic leak in the right rear axle 73Bronc 15 7,179 08-04-2009, 11:50 PM
  gears front and rear bone collector 8 5,336 07-31-2009, 08:07 PM
  Doubler/axle moved forward Questions blazinchuck 11 6,062 04-30-2009, 08:32 PM
  front sway bar KUIKUIBRONCO 15 6,510 04-20-2009, 11:52 PM
Last Post: KUIKUIBRONCO
  FSB front rotor removal tapiot 18 10,114 04-19-2009, 09:26 PM
Last Post: bone collector
  JP's New Front Bumper!!!! SC74 60 20,658 12-20-2008, 11:00 PM
  New front driveshaft badbronco 1 4,009 07-10-2008, 11:05 PM
