09-30-2007, 09:10 PM
looking good,
bryan
bryan
Front 60 Install Begins!
looking good,
bryan
09-30-2007, 09:43 PM
Robert, things are shapping up. Isn't it exciting?
carl
09-30-2007, 10:21 PM
Keep upu the good work!! thanks for keeping us posted w/ the great pics
Brian
10-01-2007, 09:18 AM
Thanks for the encouragement. It is exciting - just getting the motor mounted was a milestone for me it feels like.
I've got to figure out how to mount the sag pump - BC's bracket may be the way to go since it'll hold a compressor too - my on-board air solution. I'll find an air tank from a tractor rig and look for a creative place to mount it (maybe where the aux. tank was?). I've been talking to Jack (Ironbender) about his rear link set-up and hopefully we can come up with something for his "60 version." By the end of this week I should have the front end back together so I'll have a 1/2 rolling chassis! I just gotta figure out if the caliper bracket came off of the front or backside of the spindle (Bryan is yours still together?) and how it was clocked. Robert
10-01-2007, 03:18 PM
i will check and get back with ya
bryan
10-01-2007, 08:11 PM
SC74 Wrote:Thanks for the encouragement. It is exciting - just getting the motor mounted was a milestone for me it feels like. Robert, I've been collecting some air tanks. I have one from a big rig(paid $20) and those small twin portable tanks...just got another. Been looking and I think they would work better. Should fit right in place of the old aux.gas tank. I too need to check out the bracket from BC. HTH<Chuck
10-02-2007, 10:46 PM
best i can tell the bracket goes on first.
bryan
10-03-2007, 08:46 AM
66bronco Wrote:best i can tell the bracket goes on first. Thanks Bryan - They do go behind the spindle. I was able to line up the old markings/bruises on the pieces to fit them back together. My driver side spindle gave me trouble - I guess he had thrown an inner wheel bearing and it had chewed up just enough of the spindle to prevent the bearing from fitting. A little time with the file she was back on. High steer arms should be in next week and I'll get to work on the tie-rods and trac-bar. I gotta find the best deal on heim joints and tube. Does anybody have a tube schedule showing inside diameters of various schedules? I'm going to use the weld-in threaded bungs for the heims, but want to make sure I get the thickest wall possible while still large enough for the bung to fit in snug.
10-03-2007, 10:08 AM
i don't no if you can read this but i scaned a few pages from an old steel book shows i.d. & o.d. w/wall thickness of tubing hope it helps
Ronnie ![]() ![]() ![]()
'85 Bronco II 7" lift
BW1350 doubled 85:1 final crawl Hydro-assist steering Dana 44 front lincoln locked Ford 9" rear trac-loc Mile Marker 8000# winch http://www.gulchesorvpark.com |
Front axle | krazybronco | 1 | 778 |
02-20-2011, 11:44 PM Last Post: broncosbybart |
Stiff front end. | Rollers888 | 14 | 2,252 |
01-31-2011, 03:27 PM Last Post: Rollers888 |
RockSolid PreRunner Front Winch Bumper 92-96 | Sweat | 28 | 10,930 |
06-02-2010, 06:51 PM Last Post: jollygrngiant |
Power Steering Install? | ClemsonBronco72 | 0 | 850 |
11-11-2009, 10:49 PM Last Post: ClemsonBronco72 |
gears front and rear | bone collector | 8 | 2,911 |
07-31-2009, 08:07 PM Last Post: chuzie |
front sway bar | KUIKUIBRONCO | 15 | 2,532 |
04-20-2009, 11:52 PM Last Post: KUIKUIBRONCO |
FSB front rotor removal | tapiot | 18 | 5,742 |
04-19-2009, 09:26 PM Last Post: bone collector |
JP's New Front Bumper!!!! | SC74 | 60 | 7,900 |
12-20-2008, 11:00 PM Last Post: SC74 |
front axle vent | KMIBronco | 7 | 2,447 |
08-31-2008, 12:37 PM Last Post: Timstrk |
New front driveshaft | badbronco | 1 | 2,959 |
07-10-2008, 11:05 PM Last Post: johnpaulgolf |
