12-06-2008, 10:29 AM
is it hard to install new axle pivot bushings? i've been told that you need to disassemble the whole front suspension. then i heard that you don't need to. so which one is correct?
axle pivot bushings
12-08-2008, 06:44 PM
Although I haven't had to do it *yet*, it doesn't seem to be too bad if you have the "right" tools... Check out the how-to article on FSB... http://www.fullsizebronco.com/forum/show...hp?t=65881
Let me know how it goes and take some pics and post up your own how-to here and we'll sticky it! Thanks, JayT
12-09-2008, 06:46 PM
i will try not to forget to take some pics. thanks for the info.
12-09-2008, 11:51 PM
Not too bad at all, If you have a winch or a high lift its really easy. I prefer the rubber bushings with the pree load. Rubber is much quieter and seems to ride nicer.
Broncomatt |
Pitman arm bushings? and a couple other suspension ?'s | knoxville714 | 3 | 2,970 |
09-16-2016, 08:10 AM Last Post: Deltabronco |
C- Wedge bushings | snipes243 | 25 | 6,959 |
08-14-2015, 12:01 AM Last Post: chuzie |
Axle Tube Vents | Casey835 | 4 | 1,316 |
03-01-2013, 08:20 PM Last Post: Casey835 |
***9" Axle Gurus...Ring gear dug into pilot housing!** | chuzie | 7 | 2,302 |
12-05-2012, 12:35 AM Last Post: chuzie |
Axle / Gear gurus help!! | SC74 | 4 | 2,361 |
03-28-2012, 08:52 AM Last Post: SC74 |
F150 axle shaft tech | blazinchuck | 12 | 2,891 |
12-03-2011, 09:34 PM Last Post: broncosbybart |
Stuck rear axle? (9") | Action | 6 | 1,482 |
06-24-2011, 09:42 PM Last Post: jollygrngiant |
rear axle shims? | berg bronco | 15 | 2,330 |
01-04-2011, 09:52 PM Last Post: blazinchuck |
axle | bluebooger | 6 | 1,314 |
12-02-2010, 12:45 AM Last Post: broncosbybart |
Axle Seal Leak.. Again! | 73Bronc | 13 | 3,117 |
10-15-2010, 01:50 PM Last Post: chuzie |
