Stuck rear axle? (9")
You all are on the other side of the Country from me but have a great site and some good info. So I have a passenger side axle that is stuck and I mean stuck. It is a 73 that I have had over 25 years so may have never been apart-Not sure-I have beat-pulled- pried-cussed-used a drum for a slide hammer-What do i try next?
Thanks Jack
Had the exact same issue on my rig at URE in November. We spent all night and part of the next day trying to get that sucker out. We tried everything!!!
Anyway, what finally worked was heat, a scissors jack pushing from the back, and a hammer pounding on the axle housing around the bearing. We were at a campsite so not really the most ideal conditions plus we were under a time constraint to get back on the trail.
I would heat it up a little then use plenty of PB Blaster in the bearing area. Then let it sit overnight and try what I mentioned above.
Good luck!
a slide hammer works the best as it pulls from the center out.
03 Honda Shadow Spirit
Well I got it. a little tug and a few taps from a big (15lb) hammer and out she came.
Thanks Jack
lol...for a second, i thought ya used the skid steer to pull it. nice looking bronco, i like those corner guards in the rear. chuck
Yea-Just pulled it as tight as I could with the straps and then beat it with a sledge and bang here it came. Put a smile on my face. Now went to install pumpkin using Right Stuff-Tube was badConfusedcratchhe:
Jack
That'd a been awesome though, if you did use the skid steer to pull it out. I don't know why, I just thinks its bad A$$!
  1977 Ford Bronco rear ended 9" rebuild Crawdad 10 9,052 01-19-2017, 12:53 PM
  Rebuilding used rear leaf springs Crawdad 5 6,515 12-12-2016, 11:54 AM
  Lighted rear view mirror chuzie 6 7,716 06-20-2015, 12:18 AM
  rear main seal snipes243 5 5,042 05-03-2014, 11:45 AM
  stock rear drums scbronco 11 5,831 03-06-2014, 08:09 PM
  Late 70s Cadi rear disc brakes for 77 banjo rear end Crawdad 11 7,600 01-11-2014, 12:26 AM
  77 EB Rear Drive Shaft Dropped - Second time in six months UTFLIWGYA 4 4,145 12-01-2013, 10:38 PM
  Axle Tube Vents Casey835 4 3,567 03-01-2013, 08:20 PM
Last Post: Casey835
  Grinding sound from rear end area when driving Crawdad 10 7,879 02-09-2013, 09:33 PM
  '94 351 Rear Main replacement JayT 5 3,822 12-22-2012, 05:34 PM
