12-01-2010, 12:20 AM
Will the front axle out of a Scout II fit/work in a EB. what is the width of the EB dana 30. And does anyone know the width of the dana in the Scout II.
Thanks for any help...
axle
12-01-2010, 09:23 AM
hey, im sure the scouts are leaf sprung so its not a easy swap. your better off scoring a D44 from a 71-77 EB. not sure on the width
12-01-2010, 09:38 AM
If I remember correctly, the width of the EB is 58" or so. I also think the Scout II's are 58". But as Chuck said, I do not think the leaf to radius arm conversion would be as economical as finding an EB D44.
12-01-2010, 11:31 AM
I have an EB axle if you are looking.
12-01-2010, 11:00 PM
I was wanting to do the Disc brake swap from a chevy and I didnt think it would work on the Dana 30. I would like a Dana 44. I forgot about the scout having leaf spings. Im a long way from putting this together, Im just collecting Parts right now. when I do put it together I want to do it right the first time. Its just going to be A driver and minor offroader and possibly some beginner rock climbing.
12-02-2010, 12:45 AM
A disc swap from a chebby should be fine on the 30. The 44 is a lot stronger though.
| Axle Tube Vents | Casey835 | 4 | 3,575 |
03-01-2013, 08:20 PM Last Post: Casey835 |
| ***9" Axle Gurus...Ring gear dug into pilot housing!** | chuzie | 7 | 5,085 |
12-05-2012, 12:35 AM Last Post: chuzie |
| Axle / Gear gurus help!! | SC74 | 4 | 4,124 |
03-28-2012, 08:52 AM Last Post: SC74 |
| F150 axle shaft tech | blazinchuck | 12 | 6,655 |
12-03-2011, 09:34 PM Last Post: broncosbybart |
| Stuck rear axle? (9") | Action | 6 | 4,543 |
06-24-2011, 09:42 PM Last Post: jollygrngiant |
| rear axle shims? | berg bronco | 15 | 6,096 |
01-04-2011, 09:52 PM Last Post: blazinchuck |
| Axle Seal Leak.. Again! | 73Bronc | 13 | 7,066 |
10-15-2010, 01:50 PM Last Post: chuzie |
| 79 F150 Dana 44 Axle Question | 2000F150SAS | 3 | 4,296 |
01-31-2010, 03:53 AM Last Post: broncomania |
| "whining" rear axle! | jollygrngiant | 16 | 8,126 |
09-14-2009, 06:51 PM Last Post: chuzie |
| Front Axle | Olredneck | 0 | 1,674 |
09-03-2009, 08:44 PM Last Post: Olredneck |
