01-27-2009, 08:57 PM
John is there not a truck shop near you that can lengthen your existing drive shaft? It would be a TON cheaper.
JohnPaul's Build
01-27-2009, 09:41 PM
Jduck Wrote:John is there not a truck shop near you that can lengthen your existing drive shaft? It would be a TON cheaper. I'll prolly do that too ... for a back up ... :biggthumpup: But for now ... this was good and that way I can take my new one and my spare and say "need it like this" ... ![]() Plus I already ordered it and I'm trying to justify my spending ... :hysterical:
01-27-2009, 09:53 PM
johnpaulgolf Wrote:Plus I already ordered it and I'm trying to justify my spending ... :hysterical: Whatever you gotta tell yourself :hysterical: It sounds alot like me trying to explain my purchases ![]()
01-27-2009, 10:04 PM
johnpaulgolf Wrote:Jduck Wrote:John is there not a truck shop near you that can lengthen your existing drive shaft? It would be a TON cheaper.I'll prolly do that too ... for a back up ... :biggthumpup: Let me know if you can find someone local. I looked around Savannah for a willing victim to extend/shorten my d.shafts and came up empty, back when I swaped in my Np435. ![]()
01-27-2009, 10:15 PM
Ogeechee 4x4 Wrote:Let me know if you can find someone local. I looked around Savannah for a willing victim to extend/shorten my d.shafts and came up empty, back when I swaped in my Np435. Savannah driveline on Telfair Rd. off Chatham Parkway ... I have heard from a few good people that they are top notch ... ![]()
01-30-2009, 10:48 AM
(This post was last modified: 01-31-2009, 10:41 AM by johnpaulgolf.)
Hows this coming along?
01-30-2009, 11:06 AM
(This post was last modified: 01-31-2009, 10:42 AM by johnpaulgolf.)
CCOR Wrote:Hows this coming along? I'm hopin for my parts today ... I need to put my new to me PS pump in and then the new new Driveshaft and barke shoes and drums ... should be okay if my parts come TODAY !!! :biggthumpup:
02-01-2009, 06:29 PM
How did the driveshaft turn out?
02-11-2009, 03:47 PM
Everything worked great ... 2 1/2" lift, degreed radius arm bushings, new driveshaft, new PS pump, new C-bushings and new harmonic balancer and pulleys ... :biggthumpup:
Also added a stainless steel flex radiator hose to the top of the Radiator ... And a 400 watt kicker to my CB ... ![]() Got my spare axle out of the D44 layin in the yard and put a fresh U-joint in there and put the Bronco back together and got it off the trailer this morning.:xyxthumbs: Having a problem with the front axle being centered so Chuck sold me his adjustable Trac bar which will go in this week ... also got a few loose ends to tighten up some elec. stuff and a oil leak behind the harmonic balancer ... also had a small leak in the radiator hose ...:banghead: Monday I got a twin stick from Wild Horses ... :toothy12: Might could possibly be a decent rock rig soon... :rubeyes: :popc1: :popc1: :popc1:
02-12-2009, 01:16 AM
Great Job, JP! Let's see some pics of the new lift stance...
ECORS Class A race rig build | broncosbybart | 387 | 89,233 |
10-29-2014, 05:33 PM Last Post: broncosbybart |
1969 Bronco Build | jtoney51 | 9 | 4,301 |
My 76 LUBR Build in SC | Crawdad | 177 | 40,182 |
DWB Build Thread | DirtyWhiteBoy | 33 | 10,571 |
Welch Racing Build thread | cuz1 | 183 | 39,073 |
my bronco build | 66bronco | 65 | 18,746 |
Bighorn Build Thread | Bighorn | 70 | 17,839 |
JayT's lil 66 build | JayT | 30 | 9,191 |
The budget build | broncomatt | 104 | 29,304 |
