Welch Racing Build thread
Supposedly the tennis balls help the coil springs with hard landings and bouncing. I guess it could also work as a bump stop. We saw this on a bronco tough truck and the guy swears by them. Cheap bumpstops I guess. It looks pretty cool---good conversation piece.
I would love new arms but how can I change the frame mount so It does not affect the caster or camber which ever?
cuz1 Wrote:Supposedly the tennis balls help the coil springs with hard landings and bouncing. I guess it could also work as a bump stop. We saw this on a bronco tough truck and the guy swears by them. Cheap bumpstops I guess. It looks pretty cool---good conversation piece.
As long as you use the same degree bushings that are in the current arms the caster should not change. Those determine what angle the arms hold onto the axle.
The tennis ball trick is interesting - I bet it makes it even MORE of a PITA to change coil springs though.
What do you need from me to get the ball rolling on some new arms. Can you help me out?
cw
I followed Roberts Lead on the grill for the bronco.
[Image: DSC00610.jpg]
[Image: DSC00613.jpg]
I found this battery box in the eclosed trailer the other day--- or at least what I thought was a battery box until I opened it. WOW!!!Confusedhocked:
New Moser 3rd member with 40 spline spool.
[Image: DSC00612.jpg]
Good stuff Carl ... :biggthumpup:
Can I have that third member Confusedcratchhe:... It's not what you need :hysterical:
I have plans for it. Spidertrax 9" front and rear.
Very nice carl, what gears you gona run?
Dang Carl, you sure lucked out.
That's like finding the pot of gold w/out the leprechauns!:xyxthumbs:
broncomatt Wrote:Very nice carl, what gears you gona run?
Matt,
The 3rd member has 477 on it but I think I want to stick with 456--- give me some advice
jollygrngiant Wrote:Dang Carl, you sure lucked out.
I have more stuff that would just blow your mind. How about a new Keith Black (hemi) aluminum block, crank and pistons. Everything you need to build a top fuel motor. I have the heads and all the head stuff. 2 Blowers, dual MSD distributors. Too much to list.
Bad thing is I do not know what to do with this stuff. I guess sell it.
  77 LUBR Build in SC, Part 2 Crawdad 79 41,578 04-20-2020, 12:57 PM
  ECORS Class A race rig build broncosbybart 387 89,804 10-29-2014, 05:33 PM
  1969 Bronco Build jtoney51 9 4,310 07-09-2013, 10:26 PM
  My 76 LUBR Build in SC Crawdad 177 40,386 05-14-2013, 07:13 PM
  DWB Build Thread DirtyWhiteBoy 33 10,609 12-30-2012, 09:14 PM
  my bronco build 66bronco 65 18,825 04-17-2012, 11:54 PM
  My "built" thread nhopman 13 4,656 12-27-2011, 02:25 PM
  Bighorn Build Thread Bighorn 70 17,896 11-16-2011, 05:33 PM
  JohnPaul's Build johnpaulgolf 303 72,680 11-16-2011, 10:52 AM
  JayT's lil 66 build JayT 30 9,222 11-01-2011, 09:06 PM
