Southern Rods AC kit install..part 1-heater
chuzie...i got nothing done today! so there!
Allied bead locks? No, you need the Hutchinson 2pc DOT ones. If you're gonna go, go all out! Maybe if you make it that nice the wife will take it back. It was 'hers' right??
You are gonna have a nice ride when you're done with this thing, even without the wish list!
Legal beadlocks are for the weak. I love driving 80mph with my fingers crossed that my Allieds don't disintegrate and subsequently force me to be liable for any damage I cause to innocent bystanders!
Hell, if the circumstances are right, I could even go to jail. Ya, that's right, I'm a hardcore bada$$!
got some more air vent hose today...those people were suppose to supply some press on washer locks that hold cable on rotary switches but the box show up without them! had to go to hardware store twice to get right washers!
got the new column mounted, still waiting on cruise control lever to show up so i can run that harness down into the column. glad i got the broken bolt out for the column upper mount...nice having 2 bolts hold it in now. going back out now to try wiring up most of the rostra cruise unit. maybe tuck some under dash wires up and hopefully mount some under dash vents. i hate when my bronco is down!!!!
Hey jerkey! Wire my cruise control up too while you're at it!!!!
i am wiring yours in...
....into mine!
Its done! Cruise, tilt column, brake booster, heater and vents. Gotta adjust push rod between booster and master cylinder
Good job, Roller Boy!!
had to readjust the TPS and idle...now its running great. tested the cruise out a few times...its awesome!!!! gonna make traveling so much better.
Got everything done today!! Installed the ididit tilt column, rostra cruise control, new brake booster, and the 1st stage of Southern Rods AC/heater(heat only now). I forgot to get pics of the heater hoses... I came right off heater core and went 90° right threw kick panel, then another 90° up. I don't have the fresh air box on pass side, so I ran hose in that vacant area and routed towards front of motor. The rotary knobs were stiff...a little penetrating oil made them work smoothly. In all the mess I screwed up and put the temp control in the defrost hole and visa versa lol...no crazy bout swapping them now. Over all, I'm very happy...I wish there was more room behind dash. I will say if you take a lot of time and really route your wires up high and tight...I think these hoses will hide up behind dash better. Here are some pics
  1996 Ford Bronco- Body Bushing Install jrshepherd 2 2,411 09-19-2018, 02:50 PM
  ebay radiator(5.0 conversion) install... blazinchuck 8 5,275 10-15-2012, 10:30 PM
  bushing install ? firefighter2134 2 2,698 08-11-2011, 10:30 PM
  Oil Pressure Guage install location??? Crawdad 3 1,978 04-12-2011, 12:35 PM
  Name That Part - round 2 chuzie 12 2,498 12-31-2010, 09:56 PM
  Heater box : Name that part! chuzie 8 1,666 12-29-2010, 11:26 PM
  TRO install on my '77 chuzie 9 3,310 12-28-2010, 06:41 PM
  ididit install berg bronco 25 4,160 12-27-2010, 01:09 PM
Last Post: berg bronco
  Heater Rebuild and Upgrade scbronco 16 2,700 12-24-2010, 11:02 AM
  Mystery Part- WTH is this? jdowns67 6 1,471 10-24-2010, 10:30 AM
