Power steering pump
My power steering seems to be not so powerful. I recently installed the red neck ram and the pump seems to struggle some. Any bright ideas, or maybe a new pump.
cuz1 Wrote:My power steering seems to be not so powerful. I recently installed the red neck ram and the pump seems to struggle some. Any bright ideas, or maybe a new pump.
is it a saginaw? if so, you can bump the pressure and volume...makes it better. check out west texas offroad for the write up. I've done the mods on a couple of pumps before.
if it's not a saginaw, then get one.
Carl - I've got a sag pump that I bought off of Blane (rednck21) before I decided to go with the explorer serp. set-up. I don't remember how much I paid him but it's yours if you want it. It's got the dual return on it, but no bracket or cap.
I will take it. I want to see if it helps my situation. I almost called those guys today to ask about their pump. Send me a pm with your address and I will send you the cash.
thanks
carl
When i did the explorer swap on my front end (engine) the pump worked really well until my crappy old fitting blew out 2 years ago on the trail with chuck. Still havent fixed it but I have a good excuse. i had the saginaw prior to that and i was every pleased. also had WTOF overhaul my box as well.
  Heim Steering wepuckett 20 8,953 08-28-2015, 03:18 PM
  Steering box help snipes243 24 17,136 07-17-2015, 09:42 AM
  What type Power Steering Cooler are you all using? Broncitis 7 3,935 07-16-2015, 01:32 AM
  Steering shaft Extension Question??? Broncitis 4 4,452 04-17-2015, 02:27 PM
  Quick disconnect steering wheel snipes243 4 5,276 08-21-2012, 06:50 PM
  Power Steering issues Crawdad 31 12,522 07-28-2011, 09:29 PM
  Home made heavy duty steering Timstrk 4 4,021 11-25-2010, 10:47 AM
  power steering pumps snipes243 9 7,575 11-15-2010, 05:17 PM
Last Post: nhopman
  water pump v8 302 torque spec jrshepherd 5 4,970 11-13-2010, 10:45 PM
  v8 water pump question jrshepherd 7 3,766 11-08-2010, 10:18 AM
