CO2 tank and air compressor
Coming from the cu*t that passed on hell week? Wow! I've got ur pu*sy right here baby. Come and get it
Sent from my SAMSUNG-S3 using Tapatalk 2 on CyanogenMod
Didn't realize the list was turning into a Pirate clone.
Using a Co2 tank to hold air when empty would probably be a waste. Even a bigger Co2 tank wouldn't hold enough air to run an air tool for more than a few seconds. Plus pumping air into the tank would introduce moisture and most Co2 valves already have enough problems with icing without getting moisture from inside the tank.
Can you do it - probably can.
Should you do it - IMO not worth the effort and plumbing hardware.
I always wondered about running an inverter to power electric tools or to charge batteries for cordless tools. It would be nice to make the inverter portable so it can be moved to another vehicle in case you are working on a non-running rig at the time. Also by making it portable,on just the weekend trips when it wouldn't be needed, you could leave it back at home or at camp.
Nick
Chuck and i were wondering when you would chime in nick. We figured a little fun on the forum would generate some interest or, at the very least, some concern. Guess not. Oh well, we had fun in the process. I actually bet chuck that bart would be the first to jump in to break it up. Now i owe chuck $20!
I thought the moisture thing would come into play but really wanted confirmation from you.
Thanks for the info. Guess i gotta make a choice. Can't have it all.
Meh, I have a real job. Just checked the thread and it is already this far.
I agree with nick on the icing issue. CO2 and moisture don't mix. For tools, who needs air? Just get an 18v impact, or, don't break your junk.
Actually Chuck told me not to reply right away so he could make some coin. Just give me $10 and cut him out entirely. Smile
lol
  DIY Gas Tank? knoxville714 3 3,490 06-22-2016, 11:30 AM
  ARB compressor electrical connector snipes243 3 3,066 12-04-2015, 01:48 PM
  23 gallon tank snipes243 13 2,976 06-26-2015, 07:00 PM
  In-tank fuel Pumps snipes243 0 1,400 06-22-2015, 02:06 PM
  Cleaning an old gas tank wepuckett 11 8,084 09-11-2014, 09:44 PM
  Efi and stock fuel tank snipes243 3 1,381 12-11-2012, 03:28 PM
Last Post: Carolinaoffroad
  Question: Trans lines and Gas tank jrshepherd 0 1,481 08-24-2009, 10:22 PM
Last Post: jrshepherd
  Surfs rust in gas tank. HELP!!! Mill Knob 5 4,134 04-09-2009, 12:59 PM
Last Post: Mill Knob
  Gas tank berg bronco 3 1,722 11-13-2008, 10:44 PM
  Removing Aux Tank Straps??? High Pressure 2 2,425 05-10-2008, 10:07 PM
Last Post: High Pressure
