stock rear drums
3 weeks ago, I noticed the pass rear tire had brake fluid running down the back side of it. figured the wheel cylinder was shot so I replaced both rear cylinders. truck stopped beautifully and quit leaking. yesterday I notice its leaking again. what gives? brand new cylinders. same side that was leaking before is leaking now, at the same rate. im no drum expert, so what am I missing?
My Build Thread-
Confusedupergrin:Missing disk brakes
buy me some! otherwise... any realistic suggestions? LOL
My Build Thread-
maybe the shoes are so worn out that the wheel cylinder is over extending??
blazinchuck Wrote:maybe the shoes are so worn out that the wheel cylinder is over extending??
I guess that's a possibility... they sure seem to have a lot of meat left on em tho... ill replace em...
My Build Thread-
You sure it's not an axle seal leak?
no need in replacing them if they look good.
measure the inside of the drum as well, it could be too worn out and too big even for new shoes.
The rear wheel cylinders use little 'extension rods' from each piston to the brake shoes. If one or both of them is missing, the pistons in the cylinder will overextend and leak severely/dangerous. Only other thing I could think of would be drum size. EB's used both 10" and 11" dia drums. Are they mis-matched? Net effect would be the same scenario as well. The 11" drums were narrower, so I think that'd be hard to screw up without noticing.
Let us know what you find.
all the extension rods are there... i'll have to look at it tonight or tomorrow. I intended to last night, but the weather went south. thanks for the advice!
My Build Thread-
  1977 Ford Bronco rear ended 9" rebuild Crawdad 10 5,163 01-19-2017, 12:53 PM
  Rebuilding used rear leaf springs Crawdad 5 4,291 12-12-2016, 11:54 AM
  Lighted rear view mirror chuzie 6 4,716 06-20-2015, 12:18 AM
  rear main seal snipes243 5 2,982 05-03-2014, 11:45 AM
  Late 70s Cadi rear disc brakes for 77 banjo rear end Crawdad 11 3,876 01-11-2014, 12:26 AM
  77 EB Rear Drive Shaft Dropped - Second time in six months UTFLIWGYA 4 2,038 12-01-2013, 10:38 PM
  Grinding sound from rear end area when driving Crawdad 10 4,484 02-09-2013, 09:33 PM
  '94 351 Rear Main replacement JayT 5 1,654 12-22-2012, 05:34 PM
  5.0 rear main bearing... is it going out??? chuzie 16 3,961 12-18-2012, 04:52 PM
  Efi and stock fuel tank snipes243 3 1,380 12-11-2012, 03:28 PM
Last Post: Carolinaoffroad
