Grinding sound from rear end area when driving
I have driven my bronco about 500 miles since I've had it. I have noticed that there are no leaks coming from the drums to suggest my seals are bad, but does that mean the bearings are still good? If that isn't the problem, think it could be from the pinion area, say the pinion bearing? Again no leaks are coming from the pinion seal. Heck for all I know the hothead could be low on oil. It's so dang difficult determining exactly where the noise is coming from when ur in the drivers seat! Any help on ruling potential problems out is most appreciative.
Matt
thats tough...can u put it on jack stands and let it idle in gear to check the noise?
Guess I can put it on blocks this weekend. Just sounds scarey and stupid. Just right up my alley! Is the pinion bearing easy to fix?
not exactly...try to zero in on sound 1st-then we'll go from there
I agree with Chuck - jack it up and spin the wheels. Check the fluid in the diff. Does it differ with speed? Do you feel it or just hear it?
I noticed it for the first time this weekend. It just sounds like the start of something big. Wanna take csre of it pronto. Will raise and turn wheels by hand to see if it repeats.
Does it happen under power or during coast? In turns, straight, both? Is the sound constant? Does it sound like a train rolling on the railroad tracks? Is it rhythmic like coincident with wheel rotation? Need more details.
And HELL NO, your bearing aren't necessarily good just cuz there is not a leak. Oil breaks down over time and even faster when contaminated with moisture. NOTHING is impervious to moisture. If you have a vent, then each time that sucker heats up and cools off it is drawing moisture from the ambient air.
Do you know if it has a locker?
I got off early from Drill today and jacked up the rear with motor off and in park. Once on blocks I released the emergency brake. At that point I turned the the driver tire in a clockwise direction, the passenger tire was going counter clockwise. The grinding noise Was coming from the passenger side wheel. The hothead, transfer case, and driver side was all fairly quiet. Guess its the bearings. Is this something I can do or should I get a pro? Will look around for tech articles.
there not too bad.
1.pull drum off
2.4 retaining bolts-remove
3. try pulling on hud and slide axle shaft out.(sometimes these can rust in place making it a pain to remove)
if thats the case, use a old rim(bare-no tire), bolt it one and use that as leverage, if that dont work..locate a axle slide hammer)
use angle grinder, and cut the outer race off...remove all thats left of the bearing and use a cutting wheel on grinder to gently remove inner race.
you will need a press to install new bearing and bearing retainer(retainer can be a pain!!! and take a lot of force to press)
and dont forget new axle seal in axle housing.
holler if ya have a problem
If ur going to need to press it on i would use the press to remove too. Both ways work but the grinding method is risky if u havent done it before. If u hit the shaft, it is going to make for hell getting the new bearing on. Use caution.
U can get an axle shaft puller for rent @ autozone and advanced. I know that sucker is gonna be glued in there so save yourself a lot of headache and spring for the puller from the get go.
  1977 Ford Bronco rear ended 9" rebuild Crawdad 10 9,118 01-19-2017, 12:53 PM
  Rebuilding used rear leaf springs Crawdad 5 6,543 12-12-2016, 11:54 AM
  Lighted rear view mirror chuzie 6 7,762 06-20-2015, 12:18 AM
  rear main seal snipes243 5 5,057 05-03-2014, 11:45 AM
  stock rear drums scbronco 11 5,874 03-06-2014, 08:09 PM
  Late 70s Cadi rear disc brakes for 77 banjo rear end Crawdad 11 7,649 01-11-2014, 12:26 AM
  77 EB Rear Drive Shaft Dropped - Second time in six months UTFLIWGYA 4 4,174 12-01-2013, 10:38 PM
  Radius arm bushing cause of grinding/vibration sound? 1st Bronco 7 4,414 09-13-2013, 09:47 AM
  '94 351 Rear Main replacement JayT 5 3,848 12-22-2012, 05:34 PM
  5.0 rear main bearing... is it going out??? chuzie 16 8,385 12-18-2012, 04:52 PM
