Steering box help
I always hate when I can't get a problem to repeat itself.
I believe this is a popular option for a conversion setup if you can't find a stock 4-turn replacement.
http://www.wcb4x4.com/tech/diyrockcrawler.shtml
Do you have any vertical play in your pitman arm?
Maybe it's the nut behind the wheel??
broncosbybart Wrote:Maybe it's the nut behind the wheel??
Did you mean Clay, or the actual nut at the top of the steering column directly underneath the steering wheel?
One way is proper Tech, the other is funay.
Is anything I do 'proper tech'?
That is a diagnosis my dad gave to me years ago. Just passing his wisdom along.
Love it! Lmao! I thought same thing
The nut got the problem to reoccur. No play in the box I'm gonna take it the box off. And start looking for replacements.
For what you do I suggest the 4x4x2 conversion. A couple of people sell them on CB. West Coast I believe sells them. I believe it's a stronger box than a factory four or six turn box. Don't know if ur interested in going hydro. I have an old 70s Ford f100 2wd PS box. It's the long version. If interested let me know, will separate cheap.
Well got it out and there a little play in both the input and output shaft. Going to call west Texas offroad see what they say [Image: 7f8d512c3a1677ca00b8af37a19e6070.jpg]
They are thinking its either a crush ball or the center pin is broke.
  Heim Steering wepuckett 20 5,273 08-28-2015, 03:18 PM
  What type Power Steering Cooler are you all using? Broncitis 7 2,392 07-16-2015, 01:32 AM
  Steering shaft Extension Question??? Broncitis 4 3,116 04-17-2015, 02:27 PM
  Quick disconnect steering wheel snipes243 4 3,950 08-21-2012, 06:50 PM
  Power Steering issues Crawdad 31 6,590 07-28-2011, 09:29 PM
  Heater box : Name that part! chuzie 8 2,009 12-29-2010, 11:26 PM
  Home made heavy duty steering Timstrk 4 3,040 11-25-2010, 10:47 AM
  power steering pumps snipes243 9 5,294 11-15-2010, 05:17 PM
Last Post: nhopman
  steering column bluebooger 0 1,581 01-19-2010, 11:57 PM
Last Post: bluebooger
  HELP INSTALL POWER STEERING PBONE2000 3 1,436 12-11-2009, 01:08 PM
