#41
That just might work Bart. Thanks for the input, My mind was drawing a blank. LOL
Broncitis Wrote:That just might work Bart. Thanks for the input, My mind was drawing a blank. LOL
Woooo I got the seats and lap belts in today. Very comfortable and ride height seems to be 1 inch or so higher than stock seats. The starter solenoid decided to die now. So its back to town I go.[Image: 134b6c3ccd38c2834115294d8c9ffc11.jpg]
The bolts I was trying to think of are called Elevator bolts. They have a square shank like a carriage bolt and a flat head like a washer. What I ended up using were button head allen bolts and the heads on them cleared the sliders fine.
broncosbybart Wrote:Not sure on bolts. On nuts they do a jam nut that is thinner. I would probably use a button head allen head type bolt. They are pretty low profile.
After further troubleshooting the start or should I say failure to start situation it appears the Ignition switch start circuit has puked. I checked with several of the bronco suppliers and was shocked that they want nearly 20 bucks to ship a new one. I refuse to be gouged like that on such a small item. I guess I will be putting a universal switch in it.
check with some where like amazon or summit see if they have it, sure you could find enough from summit to get free shipping once you find a couple other things you want
Awight I got it worked out with the start. I got 2 bad solonoids in a row from Advance Auto. BMD was the brand. The only other brand I could find local was Duralast Gold and the first one from there corrected the problem, it came from Auto Zone.
I made the shift knobs for the Twin Sticks today also.[Image: b2091881a6d7e677cbab1d88bb2f4044.jpg][Image: 31483fc5197b8060a9361686c48ca4a5.jpg]
thats freaking awesome dwight, thinking out of the box!!!
I'm thinking it is time to send the Power Steering box to West Texas Offroad and get it rebuilt. The only problem is the seals are leaking and getting worse. Has anyone ever replaced the seals and if so did they hold up? Not sure about these seals being available locally but do you think it would be worth a try in order to reduce down time and save some cash.
It is doable. Here are a couple links that might help. Some seal kits are more complete than others.
http://classicbroncos.com/forums/showthr...ox+rebuild
An article on rebuilding a Saginaw box (a bit different but gives you the idea)
http://www.fourwheeler.com/how-to/transm...x-rebuild/
  Lil Red Riding Hood Build Broncitis 11 7,340 03-04-2016, 12:14 AM
  Manual brake push rod??? chuzie 13 5,043 01-06-2014, 03:04 PM
  Irmo73's Build Irmo73 159 28,439 03-09-2012, 01:13 PM
Last Post: Irmo73
  92 Fullsize Build - Scotts Bronco nitro 44 10,291 01-12-2012, 08:45 AM
Last Post: nitro
  Please educate me on 3 speed trans RAT & RAN? Mill Knob 11 6,594 01-11-2011, 10:34 PM
Last Post: Mill Knob
  Stock 66 interior rebuild thread 66stocker 37 12,488 04-03-2010, 11:07 AM
Last Post: 66stocker
  Need Tie-Rod Reamer 2000F150SAS 0 1,767 10-20-2009, 08:33 AM
Last Post: 2000F150SAS
  miscellaneous ford tech thread... blazinchuck 0 2,625 02-17-2009, 11:02 AM
  70 early bronco (mild build up) broncomania 8 2,413 12-09-2008, 11:56 PM
  My new horse: 1991 Bronco trail build. manny 5 5,075 09-11-2008, 12:54 PM
Last Post: manny
