Which Motor Should I Use?
ok I have a factory 302 out of a 71 Bronco, it's complete and pretty sure it runs (havn't tried it in a while) or I have a factory 302
fuel injected out of a 90 ford car. Which would u use?
I am a dinosaur and I prefer a carb. Most of the other guys are big Fuel Injection fans. I hate sensors and all the problems they present and have a;ways been good at building/tuning carbs so there you go its all a personal preference thing.
I've always liked the carbs. And i'm not sure what can of worms I would be opening when putting in the computer and sensors.
What kind of car did the EFI engine come from? Do you have all of the wiring/etc?
EFI is much more involved than slapping a carb on something but the end result is better when it's working correctly. The 89-93 MAF mustang engines are what most folks seem to use and parts are becoming scarce.
If I am not mistaken they also get the 5.0 engines out of explorers which are also becoming harder to find but you need the wirring harness from the vehicle with the computer or you will be buying a computer and making a or buying a wirring harness.
broncosbybart Wrote:What kind of car did the EFI engine come from? Do you have all of the wiring/etc?
I want to say a Mercury cougar. I have everything including the whole car.
Harness will be a can of woms. Stick with carb if u cant go Mustang or Explorer EFI.
chuzie Wrote:Harness will be a can of woms. Stick with carb if u cant go Mustang or Explorer EFI.
That's what I figured. Thanks guys
  motor help!!!!! broncatron 6 3,935 07-09-2013, 10:03 PM
Last Post: broncatron
  motor issues please help!! bigredbronco 9 2,071 12-22-2012, 11:30 AM
Last Post: bigredbronco
  Blown Motor. NateMob 22 6,957 11-02-2011, 09:26 PM
Last Post: NateMob
  Specs for 351W motor mount bolts? 73Bronc 11 3,026 09-27-2011, 11:36 PM
Last Post: 73Bronc
  Swapped the motor in my Centurion and added a turbo! smooth 4 1,680 12-11-2009, 01:43 PM
  Motor Mount locations JayT 8 1,784 08-19-2009, 01:09 AM
  90 Transfer Case Motor Question 2000F150SAS 0 819 08-03-2009, 01:05 PM
Last Post: 2000F150SAS
  good motor find and c4 cuz1 13 3,353 12-08-2008, 08:31 AM
Last Post: DeTowman
  Finished 69 project after blowing my motor gigabytethis 3 2,476 11-10-2008, 02:41 PM
Last Post: gigabytethis
  Motor Swap Question?? BigBird13 5 1,623 10-16-2008, 07:36 PM
Last Post: BigBird13
