04-12-2008, 12:49 PM
66bronco has a tubing bender. I'm sure we can fixer' up!
BII 302 Swap
04-12-2008, 03:04 PM
I'm sure you can and If i start mine first I'll share the info as I go. That is if'n I ever figure the thumbnail thang out.
04-12-2008, 03:08 PM
BTW where you fellers located?
04-12-2008, 10:34 PM
Cool now I see it.
04-13-2008, 06:46 PM
:biggthumpup:A 302 in a B2, I'm all ears!!:notworthy:
04-14-2008, 08:06 AM
trkbilder Wrote::biggthumpup:A 302 in a B2, I'm all ears!!:notworthy: :rubeyes:But it wont be stock:hysterical: juzz ribb'n ya trkbilder, but there are a few around with 302's.
04-14-2008, 08:17 AM
When I finally wear my 2.9 out I'm wanting to do a 4.0 swap, so the 302 swap is something I might be interested in. Gas has got to come down first, mine will be a daily driver!
04-14-2008, 09:42 AM
Just get one of those computers that shut down 4 of they cylinders when not needed.
04-14-2008, 02:02 PM
trkbilder Wrote:When I finally wear my 2.9 out I'm wanting to do a 4.0 swap, so the 302 swap is something I might be interested in. Gas has got to come down first, mine will be a daily driver! I hear ya on the gas prices, and there are a lot of guys that have done the 302 swap I hear its a lot easier if ya have a body lift. But it will clear without the BL its just a bit tight in the firewall area. |
Need input on my NV4500 swap!! | knoxville714 | 12 | 6,321 |
06-20-2016, 09:59 PM Last Post: blazinchuck |
Manual to Auto swap and Auto to manual swap | wepuckett | 1 | 1,804 |
07-24-2014, 03:26 PM Last Post: wepuckett |
Brake problems after the 5.0 swap. | BucknEB | 10 | 3,043 |
10-29-2012, 03:07 PM Last Post: BucknEB |
who's running 302-4r70w-zf-d20 j shift-twin sticks? | chuzie | 2 | 1,306 |
12-11-2011, 10:14 PM Last Post: chuzie |
AOD SWAP TO A C6 | markharrell | 3 | 1,931 |
09-30-2011, 09:18 AM Last Post: jollygrngiant |
1973 Bronco 302 | mcgyver | 6 | 2,613 |
01-30-2011, 10:58 PM Last Post: Crawdad |
water pump v8 302 torque spec | jrshepherd | 5 | 3,637 |
11-13-2010, 10:45 PM Last Post: Casey835 |
Carburetor and intake manifold 1974-302-auto | jrshepherd | 6 | 3,415 |
03-04-2010, 02:08 PM Last Post: jrshepherd |
saginaw swap | chulo2004 | 6 | 5,333 |
02-07-2010, 10:10 AM Last Post: DeTowman |
Torque Spec. Spark Plugs- 1974 302 v8 | jrshepherd | 4 | 2,325 |
01-24-2010, 12:47 PM Last Post: jrshepherd |
