1973 Bronco 302
What is a good inexpensive battery to get for my build?
[Image: 30bfex1.jpg]
Thanks in advance for the input..
What's the goal for your build? Aux lights, winch, stereo system...etc???All depends on what you wanna run. If it's none of these, then a typical Auto Zone or Advance Auto battery should be fine. Other wise I'd run a optima red or yellow top.
jollygrngiant Wrote:What's the goal for your build? Aux lights, winch, stereo system...etc???All depends on what you wanna run. If it's none of these, then a typical Auto Zone or Advance Auto battery should be fine. Other wise I'd run a optima red or yellow top.
Just lookin to spin the motor fast to work out bugs. I dont know what is done to the motor and my current battery doesnt spin the motor very fast.
I just changed the fuel pump and I seem to be building pressure in the fuel lines.
going to pull the carb and check the floats and seats.
mcgyver, Welcome to CB4x4....Looks like the makings of a nice project you bought there. I'd have the battery tested to see if it's still good....It may not be your problem or else it may need to be fully charged....Make sure all your cable connections at the battery, solenoid, and starter are all clean and tight....
:rockon: EARLY BRONCOS ROCK :rockon:
looks like you have a good project vehicle. thanks for posting it.
for sure check the battery condition first. advance or autozone can load test it for you. if it is ok, the battery and starter cables in these old trucks leaves a lot to be desired. it could very well be the wiring or a tired starter and not the battery. cables are cheap and available at any parts warehouse. i found some new 'hi torque' starters at DB electrical for $40. Been pretty pleased w/the one I got from them for the price.
broncosbybart Wrote:looks like you have a good project vehicle. thanks for posting it.
Thanks for the input. I placed the battery on charge and it wouldn't chare overnight so I,m going to pickup a battery and a new high torque starter sounds like a good purchase anyway.
Go online @ Advance Auto and you get 15% discount on any battery I think. Order it online and pick it up at the store.
  1996 Ford Bronco- Body Bushing Install jrshepherd 2 4,571 09-19-2018, 02:50 PM
  Stainless/ Coated Headers needed- 1995 Bronco 351 Windsor .20 over trick flow heads jrshepherd 1 4,966 05-22-2018, 09:38 PM
  1977 Ford Bronco rear ended 9" rebuild Crawdad 10 9,170 01-19-2017, 12:53 PM
  BC Bronco Soft Top knoxville714 3 5,172 07-12-2016, 08:04 PM
  1996 Bronco New BSD 4" long arm lift on IFS suspension- Setting Wheelbase jrshepherd 11 7,078 01-31-2016, 03:55 PM
  Another Bronco Floor Replacement jdowns67 83 33,378 12-20-2014, 11:33 AM
  Mystery Bronco, need your expertise to solve 1st Bronco 2 4,520 08-04-2013, 10:48 PM
Last Post: 1st Bronco
  OK. I love my Bronco again Timstrk 3 4,488 05-19-2013, 08:43 PM
  Bronco Help Around Greenwood Jbass 29 20,373 01-20-2013, 03:16 PM
  Bronco techs in/near Raleigh? Mbowles 10 5,772 11-30-2012, 07:07 PM
Last Post: Mbowles
