BII 302 Swap
66bronco has a tubing bender. I'm sure we can fixer' up!
I'm sure you can and If i start mine first I'll share the info as I go. That is if'n I ever figure the thumbnail thang out.Confusedcratchhe:Confusedupergrin:
BTW where you fellers located?
In the middle of NC.
Cool now I see it.
:biggthumpup:A 302 in a B2, I'm all ears!!:notworthy:
trkbilder Wrote::biggthumpup:A 302 in a B2, I'm all ears!!:notworthy:
:rubeyes:But it wont be stock:hysterical: juzz ribb'n ya trkbilder, but there are a few around with 302's.
When I finally wear my 2.9 out I'm wanting to do a 4.0 swap, so the 302 swap is something I might be interested in. Gas has got to come down first, mine will be a daily driver!Confusedmokin:
Just get one of those computers that shut down 4 of they cylinders when not needed.
trkbilder Wrote:When I finally wear my 2.9 out I'm wanting to do a 4.0 swap, so the 302 swap is something I might be interested in. Gas has got to come down first, mine will be a daily driver!Confusedmokin:
I hear ya on the gas prices, and there are a lot of guys that have done the 302 swap I hear its a lot easier if ya have a body lift. But it will clear without the BL its just a bit tight in the firewall area.
  Need input on my NV4500 swap!! knoxville714 12 9,150 06-20-2016, 09:59 PM
  Manual to Auto swap and Auto to manual swap wepuckett 1 2,774 07-24-2014, 03:26 PM
  Brake problems after the 5.0 swap. BucknEB 10 5,226 10-29-2012, 03:07 PM
  who's running 302-4r70w-zf-d20 j shift-twin sticks? chuzie 2 2,219 12-11-2011, 10:14 PM
  AOD SWAP TO A C6 markharrell 3 3,071 09-30-2011, 09:18 AM
  1973 Bronco 302 mcgyver 6 4,004 01-30-2011, 10:58 PM
  water pump v8 302 torque spec jrshepherd 5 4,970 11-13-2010, 10:45 PM
  Carburetor and intake manifold 1974-302-auto jrshepherd 6 4,955 03-04-2010, 02:08 PM
Last Post: jrshepherd
  saginaw swap chulo2004 6 6,927 02-07-2010, 10:10 AM
Last Post: DeTowman
  Torque Spec. Spark Plugs- 1974 302 v8 jrshepherd 4 3,659 01-24-2010, 12:47 PM
