break light switch 68 bronco
:banghead:Have been fooling with this switch and can not get the lights to work. I have put a bushing in the rod and still nothing. There is power to the plug. I have it installed on the flat part of the push rod. I cant find a pic on the internet to make sure it is installed right... any advice? thanks Sean
seanrook Wrote::banghead:Have been fooling with this switch and can not get the lights to work. I have put a bushing in the rod and still nothing. There is power to the plug. I have it installed on the flat part of the push rod. I cant find a pic on the internet to make sure it is installed right... any advice? thanks Sean
hope this helps...
  1996 Ford Bronco- Body Bushing Install jrshepherd 2 4,467 09-19-2018, 02:50 PM
  Stainless/ Coated Headers needed- 1995 Bronco 351 Windsor .20 over trick flow heads jrshepherd 1 4,884 05-22-2018, 09:38 PM
  1977 Ford Bronco rear ended 9" rebuild Crawdad 10 8,891 01-19-2017, 12:53 PM
  BC Bronco Soft Top knoxville714 3 5,049 07-12-2016, 08:04 PM
  1996 Bronco New BSD 4" long arm lift on IFS suspension- Setting Wheelbase jrshepherd 11 6,863 01-31-2016, 03:55 PM
  Headlight/Dimmer Switch??? Broncitis 4 2,534 03-30-2015, 03:39 PM
  Another Bronco Floor Replacement jdowns67 83 32,247 12-20-2014, 11:33 AM
  Mystery Bronco, need your expertise to solve 1st Bronco 2 4,436 08-04-2013, 10:48 PM
Last Post: 1st Bronco
  OK. I love my Bronco again Timstrk 3 4,397 05-19-2013, 08:43 PM
  Bronco Help Around Greenwood Jbass 29 19,913 01-20-2013, 03:16 PM
