JunKeBluB2 doubler build (lotta pics)
This build started as a BW1350 twin stick & it can be done the doubler case goes behind the t-case but i'd have to build bearing blocks, shafts, move rear axle back and more modifying than I wanted to do so i opted for what all RBV wheelers do, a doubler. A lot more to it than posted here. But here's the skinny of it.
The patient
[Image: 1SIDEVIEW.jpg]
The transplant
[Image: 2thetransplant.jpg]
The operating room (my machine shop)
[Image: 3theoperatingroom.jpg]
Remove planetary from doubler case
[Image: 5planetaryremoved.jpg]
Split the case
[Image: 6splitcase.jpg]
Back half & parts junk (unless u need them krazybronco)
[Image: 7backjunk.jpg]
Layout adapter plate & transfer holes
[Image: 8layoutplate.jpg]
Cut plate
[Image: 9cutplate.jpg]
Machining output shaft (others have used shafts from trannys and pressed and welded but I wanted more strength pics show what I mean)
Turning output shaft
[Image: 10turnoutputshaft.jpg]
Machining splines on output
[Image: 11splineoutputshaft.jpg]
Boring sector shaft
[Image: 12boresectorshaft.jpg]
Cutting square bore in sector shaft (this is for torque strength)
[Image: 14machsqrsectorshaft.jpg]
Machining square on output shaft to press into sector shaft
[Image: 15machsqroutputshaft.jpg]
shafts machined
[Image: 16readyforassy.jpg]
Pressed & welded
[Image: 17weldedandfaced.jpg]
Boring adapter plate
[Image: 18boringplate.jpg]
Machining doubler case for filler block
[Image: 19machforfillerblock.jpg]
Locating bore for drilling mounting holes
[Image: 20locatebore.jpg]
Drilling holes for mounting to t-case planetary cover
[Image: 21drillingmountholes.jpg]
Adapter plate done
[Image: 22adapterdone.jpg]
Doubler case and parts ready for assembly
[Image: 23doublercase.jpg]
Transfer & drill & tap holes in t-case planetary cover
[Image: 24tapplanetarycover.jpg]
Now I'm ready for assembly (I hope!)
[Image: 25caseassy1.jpg]
Put front cover on t-case
[Image: 26coverontcase.jpg]
Bolt adapter plate to doubler case
[Image: 27plateondoubler.jpg]
From inside doubler case bolt to t-case w/ 20 1/4 SHCS
[Image: 28doublertotcase.jpg]
Next installed shift rail (length cut) shift fork and sector shaft outer-spline
[Image: 29forkrailgearinstall.jpg]
Install planetary set in doubler case then bolt t-case to doubler case
[Image: 30tcasetodoubler.jpg]
Shifter linkage. This was the hardest part I opted to use manual shift cases cause I don't like electric shift. I had about 2 days of design in it trying to clear everything & make the shifter & arm on the t-case travel the same distance on a different radius
[Image: 31shifterlinkage.jpg]
Everything installed (I hope again)
[Image: 32installed.jpg]
Two manual shifters one shift knob (shift knob donations please)
[Image: 33dualshifters.jpg]
'85 Bronco II 7" lift
BW1350 doubled 85:1 final crawl
Hydro-assist steering
Dana 44 front lincoln locked
Ford 9" rear trac-loc
Mile Marker 8000# winch
http://www.gulchesorvpark.com
wow is not enough, but WOW, what a beautiful job Ronnie. You have some serious skills bro!! Did you have to modify the cross member or add to it?
on a side note, I saw your son on the gutches site...is he online with us yet? Whats his rig look like?
maybe you should offer this as a BII upgrade 8) Very cool,very well laid out! Chuck
Thanks Chuck for the kind words but I have been doing machine work and some design for a long time (30+ years) don't do much now though kinda semi-retired as for my son junkyarddog he's only 15 and drives a '99 dodge 1500 4x4 w/4" lift & 31 all terrains (wish I was that lucky when I was his age) as for as the post on the build I could fill a book with all that was involved oh yea didn't mod the cross member yet with the 20 mounting holes I clocked the t-case up & w/ my D44 high pinion front I hope the front shaft will clear
Ronnie
very cool.
bryan
Build me one i need one with the 3.45 gears i think you have a something around 6.something :1
SICK i want one heck chuck you still got that d44 eb
What the Confusedhock: , who the Confusedhock: , Holy crap that is cool 8) , what a great shop to have esp for a 4 wheeler.
Krazybronco,
with 3.96:1 in tranny w/ 2.48:1x2 in t-cases & 3.50:1 in axles its at 85:1 final
and you can use my shop any time you won't to build your own :lol: :lol:
69bronco
thanks,it is cool having the equipment & experience to do this stuff, but I don't do as much as I use too.
oh yea thanks Bryan but you need to get your's off the stands and on the trails the JUNK might need a tow!
I have been looking for a small manual mill and lathe to put in my shop. Just have not been lucky yet.
bryan
  77 LUBR Build in SC, Part 2 Crawdad 79 61,978 04-20-2020, 12:57 PM
  ECORS Class A race rig build broncosbybart 387 164,587 10-29-2014, 05:33 PM
  1969 Bronco Build jtoney51 9 7,878 07-09-2013, 10:26 PM
  My 76 LUBR Build in SC Crawdad 177 70,764 05-14-2013, 07:13 PM
  DWB Build Thread DirtyWhiteBoy 33 18,148 12-30-2012, 09:14 PM
Last Post: DirtyWhiteBoy
  Welch Racing Build thread cuz1 183 71,359 11-03-2012, 08:04 PM
Last Post: Casey835
  my bronco build 66bronco 65 32,692 04-17-2012, 11:54 PM
Last Post: bigjake79
  Bighorn Build Thread Bighorn 70 33,254 11-16-2011, 05:33 PM
  JohnPaul's Build johnpaulgolf 303 142,572 11-16-2011, 10:52 AM
  JayT's lil 66 build JayT 30 15,934 11-01-2011, 09:06 PM
