90 Bronco Ball Joint Replacment
Any one have Tech Artical for replacing ball joints?
Thanks
I have several shop manuals, alldata, or I can just try and tell you. I will say you need a ball joint tool. I got mine from OTC, not cheap! You can rent them from most parts stores, not sure how much.
I wont be able to write something up untill tonight, busy day at work.
I found this link, it's not bad i'm just not sure about the 4x4 hub removal i never done one of these. (We have Auto. Hubs)
Any help would be great, thanks
http://www.off-road.com/trucks4x4/articl...?id=198389
John
ahh... pulling off the hub is relatively easy. You'll need a hub socket (I'll lend ya mine, if you want)... Removal of the ball joint is the hardest part, but that might just be the years of wheelin mine before I had them done. (yeah, I had a shop do my ball joints, while they had my ride, putting in my gears). There's a few points that I lost.
Gimme a few and I'll post up a PDF from Alldata...
JayT
Here's a PDF from AllData... let me know if you need my hub socket... or a hand... I'll meet ya around McGees Crossroads - I should be around all day.
.pdf   1990 Ford Truck Bronco Full Size Ball Joints .pdf (Size: 126.22 KB / Downloads: 306)
BIG THANKS for JAYT!!:biggthumpup:
I know what i'm doing New Years Day.
John
No prob... That's what we're here for! Makes it easy when you ask about the same ride I've got! Smile
give me a holler if you need a hand.
JayT
Go JayT go JayT go JayT go JayT ... :biggthumpup: :notworthy: Confusedmokin:
Gotta love the "CREW" ... see ya ... :chili:
Confusedmokin:
:popc1:
  1996 Ford Bronco- Body Bushing Install jrshepherd 2 4,528 09-19-2018, 02:50 PM
  Stainless/ Coated Headers needed- 1995 Bronco 351 Windsor .20 over trick flow heads jrshepherd 1 4,943 05-22-2018, 09:38 PM
  1977 Ford Bronco rear ended 9" rebuild Crawdad 10 9,077 01-19-2017, 12:53 PM
  BC Bronco Soft Top knoxville714 3 5,131 07-12-2016, 08:04 PM
  1996 Bronco New BSD 4" long arm lift on IFS suspension- Setting Wheelbase jrshepherd 11 7,009 01-31-2016, 03:55 PM
  Another Bronco Floor Replacement jdowns67 83 32,843 12-20-2014, 11:33 AM
  Mystery Bronco, need your expertise to solve 1st Bronco 2 4,493 08-04-2013, 10:48 PM
Last Post: 1st Bronco
  OK. I love my Bronco again Timstrk 3 4,459 05-19-2013, 08:43 PM
  Bronco Help Around Greenwood Jbass 29 20,198 01-20-2013, 03:16 PM
  Bronco techs in/near Raleigh? Mbowles 10 5,707 11-30-2012, 07:07 PM
Last Post: Mbowles
