Bronco sat...now won't start...Help!
I have neglected my pride and joy. I admit, I suck. Long story short, we moved, remodeled, and now 6 months later bronco will not start.
I have tried jumping it, shaking it, etc. If I pour gas in the carb and some ether she will run for 1-2 seconds and then just shut off hard. Sounds as if she wants to fire but will not catch. Any ideas? Was running fine. Drove her to the new house, about 45 minutes, no issues.
I have tried cleaning the carb, new fuel filter etc. The gas had stabilizer in it. Anyone is the Raleigh care to help a brother out? Many Thanks
Nick
Trying to make it Happen!
If it starts with some gas dumped in the carb its fuel related. First thing that comes mind is the fuel pump. Take the gas cap off, take the fuel line off the carb. Crank it over and see if fuel comes out of the hose(dont set it on fire).
If that doesnt pump fuel its the pump.
Some times you can pressurize the tank with compressed air to force fuel into the pump to help prime it. Hope that helps.
I will try that and see what happens. Killing me just sitting there.
Do you spray canned air in and put the cap on?
You can pressuize the tank with shop air, only do it quickly. Its just to move the gas up the fuel line. Then leave the cap off, and try to crank it over. Fuel should be comming out hose to the carb. Poor mans way of primming a starved fuel pump.
where are you in Raleigh?
[Image: Outalne_017.gif]
on six forks right off of 540 towards the country. I actually just moved from Clayton, 6 months ago>
  1996 Ford Bronco- Body Bushing Install jrshepherd 2 4,513 09-19-2018, 02:50 PM
  Stainless/ Coated Headers needed- 1995 Bronco 351 Windsor .20 over trick flow heads jrshepherd 1 4,930 05-22-2018, 09:38 PM
  1977 Ford Bronco rear ended 9" rebuild Crawdad 10 9,048 01-19-2017, 12:53 PM
  BC Bronco Soft Top knoxville714 3 5,117 07-12-2016, 08:04 PM
  1996 Bronco New BSD 4" long arm lift on IFS suspension- Setting Wheelbase jrshepherd 11 6,978 01-31-2016, 03:55 PM
  Another Bronco Floor Replacement jdowns67 83 32,682 12-20-2014, 11:33 AM
  t-shift t-case won't go into 4-lo scbronco 3 3,954 04-01-2014, 09:54 AM
  Mystery Bronco, need your expertise to solve 1st Bronco 2 4,480 08-04-2013, 10:48 PM
Last Post: 1st Bronco
  OK. I love my Bronco again Timstrk 3 4,442 05-19-2013, 08:43 PM
  Bronco Help Around Greenwood Jbass 29 20,148 01-20-2013, 03:16 PM
