how tough is your bronco
I didnt get to work on my broncos this weekend, I had noticed a pine tree in the shop parking area that had started to lean more so than in the past.
It was an 80' tree that leaned toward my shop. There were other trees that needed to be dropped before I could get the pine down.
I dropped the 2 other hard woods (80-100'tall) first. Then I hooked up the pine with a snatch block to my eb. I cut my relief cut and motioned to liz to put tension on the tree to be sure it could not fall on the shop. In that process liz stalled the bronco, restarted it and floored in reverse.
Before I could even finish the back cut liz pulled the entire tree over!:rubeyes:
She pulled it strait down where I wanted it, with out even cutting threw the tree, stump and all. Confusedmokin:
Thats how tough my ride is :thefinger:
It was all Liz. Had nothing at all to do with your Bronco. She could have done the same thing with a Fort Escort. Confusedupergrin:
Not a Bronco owner, but a Bronco enthusiast!
Doing big things......On leaf springs and 37's!
1984 CUCV Blazer 6.2 diesel, SM465/NP205 Dana 60, 14 bolt, detroits, recentered H1 double beadlocks, 37 inch military Goodyears.
Confusedcratchhe: Go figure. Put a gal in an Early Bronco and her alter-ego always shows up (Wonderwoman)....
Confusedcratchhe: Oops, don't kn..kn..know (stutter) how those double posts happened....
Hold on there bro. All that you and don't even have a picture? I am going to raise the B.S. flag on this one my friend!
id like to see a jeep try that. glad everything went well
Lifes a garden dig it
There's no pic because the truth is it was my Stealth that pulled it out! hahaha
:twothumbs:
Aha, now that Liz has checked in, does the real truth of the matter begin to come out? :error: Matt, do you wish to recant your previous testimony and do you swear to tell the truth, the whole truth, and nothing but the truth, so help you God??
For the record liz's stealth was in the shop getting the oil changed:banghead:, it may be fast but its no match off road for a bronco:notworthy:
exhibit A
[Image: fg.jpg]
[Image: aew54.jpg]
[Image: 565.jpg]
There are 2 hard wood trees in those shots that were notched and then pulled over by my eb too. The fun is after I cut the trunks to log length (20') I drag them out back to my landing pad for storage. Wheeling in your own back yard is so much fun:bdent::drinkbud:
  BC Bronco Soft Top knoxville714 3 5,124 07-12-2016, 08:04 PM
  1996 Bronco New BSD 4" long arm lift on IFS suspension- Setting Wheelbase jrshepherd 11 6,989 01-31-2016, 03:55 PM
  Another Bronco Floor Replacement jdowns67 83 32,769 12-20-2014, 11:33 AM
  Mystery Bronco, need your expertise to solve 1st Bronco 2 4,483 08-04-2013, 10:48 PM
Last Post: 1st Bronco
  OK. I love my Bronco again Timstrk 3 4,452 05-19-2013, 08:43 PM
  Bronco Help Around Greenwood Jbass 29 20,161 01-20-2013, 03:16 PM
  Bronco techs in/near Raleigh? Mbowles 10 5,693 11-30-2012, 07:07 PM
Last Post: Mbowles
