Engine help
So I was having issues with the intake gasket leaking pretty bad. So I decided to change it. When I was messing around with it last week I was get coolant coming out from under the intake gasket. Which I was told was common if the intake gasket wasn't properly seated. After I took the intake off I examined the ports and found a 1/8" hole in the passenger front coolant passage. It doesn't look like its suppose to be there isn't going to hurt anything or should I take the head off to be sure?
FYI the pictures are upside down for some reason
It is really hard to see anything in the pics. Let me know if you need more info after we talked.
Compression test checked out ok
I figured it would. It ran too good to have a major compression issue. When it is complete, you can also do a pressure test on the cooling system. You might be able to get a loaner tool to do it. Basically a radiator cap with a pressure pump built into it to check for pressure losses/leaks.
Will do I went ahead and JB welded the hole. I think it was just going to a void in the casting
Jb weld is holding. I put coolant pressure tester on it today, the gauge holds steady no leaks.
Just saw this.
Never seen a hole like that before. Luckily you were able to patch it from the inside so hopefully the pressure will hold. My concern is towards how well the JB weld is going to handle the heating / cooling cycles.
Anyway, I assume this discovery was purely coincidental and had nothing to do with the leak, right?
What head are they?
Yep just happend to see them when I was check for particles in the head. The jb weld I used is rated to 500 degrees
The heads are stock truck heads
Got it running and mantaining temp. I think my fix worked
  Automatic Trans: Why does the engine die as soon as I put it in Park or Neutral???? UTFLIWGYA 6 6,090 05-15-2014, 11:50 AM
Last Post: rbodine
  Can firing order determine engine block size? 1st Bronco 1 2,017 08-16-2013, 06:26 PM
  5.0/nv3550...engine now dies at stops*help* blazinchuck 14 7,049 06-09-2013, 10:50 AM
  1996 5.8 L Engine Rebuild- Cylinder heads jrshepherd 0 3,422 07-17-2011, 11:13 AM
  Engine Rebuild. 1996 5.8 L jrshepherd 0 1,743 05-05-2011, 02:02 AM
  new engine berg bronco 21 9,134 05-12-2009, 11:38 PM
Last Post: supertoyota88
  Engine build advice cuz1 6 3,455 06-27-2008, 05:35 PM
  engine taching a bit high? bowtieman55 12 7,170 04-01-2008, 08:05 PM
