Engine Rebuild. 1996 5.8 L
Im down to 30 lbs in my #1 cylinder. I 'm going to do a complete rebuild. I'm going to use the stcok ECM and did not to step jumb to a new PCU. Tell me your ideas?
  1996 Ford Bronco- Body Bushing Install jrshepherd 2 4,536 09-19-2018, 02:50 PM
  1977 Ford Bronco rear ended 9" rebuild Crawdad 10 9,099 01-19-2017, 12:53 PM
  1996 Bronco New BSD 4" long arm lift on IFS suspension- Setting Wheelbase jrshepherd 11 7,024 01-31-2016, 03:55 PM
  Automatic Trans: Why does the engine die as soon as I put it in Park or Neutral???? UTFLIWGYA 6 6,102 05-15-2014, 11:50 AM
Last Post: rbodine
  Engine help snipes243 12 6,494 02-21-2014, 12:06 AM
  Can firing order determine engine block size? 1st Bronco 1 2,030 08-16-2013, 06:26 PM
  5.0/nv3550...engine now dies at stops*help* blazinchuck 14 7,081 06-09-2013, 10:50 AM
  1996 5.8 L Engine Rebuild- Cylinder heads jrshepherd 0 3,428 07-17-2011, 11:13 AM
  1996 5.8L spark plug wires and coil jrshepherd 0 1,819 02-08-2011, 06:16 PM
  PCV Grommet 1996 5.8L jrshepherd 5 3,889 01-03-2011, 11:14 PM
