02-07-2008, 04:19 PM
My power steering seems to be not so powerful. I recently installed the red neck ram and the pump seems to struggle some. Any bright ideas, or maybe a new pump.
Power steering pump
02-07-2008, 04:44 PM
cuz1 Wrote:My power steering seems to be not so powerful. I recently installed the red neck ram and the pump seems to struggle some. Any bright ideas, or maybe a new pump. is it a saginaw? if so, you can bump the pressure and volume...makes it better. check out west texas offroad for the write up. I've done the mods on a couple of pumps before. if it's not a saginaw, then get one.
02-08-2008, 05:01 AM
Carl - I've got a sag pump that I bought off of Blane (rednck21) before I decided to go with the explorer serp. set-up. I don't remember how much I paid him but it's yours if you want it. It's got the dual return on it, but no bracket or cap.
02-08-2008, 03:51 PM
I will take it. I want to see if it helps my situation. I almost called those guys today to ask about their pump. Send me a pm with your address and I will send you the cash.
thanks carl
02-20-2008, 06:29 AM
When i did the explorer swap on my front end (engine) the pump worked really well until my crappy old fitting blew out 2 years ago on the trail with chuck. Still havent fixed it but I have a good excuse. i had the saginaw prior to that and i was every pleased. also had WTOF overhaul my box as well.
| Heim Steering | wepuckett | 20 | 9,472 |
08-28-2015, 03:18 PM Last Post: wepuckett |
| Steering box help | snipes243 | 24 | 17,778 |
07-17-2015, 09:42 AM Last Post: snipes243 |
| What type Power Steering Cooler are you all using? | Broncitis | 7 | 4,152 |
07-16-2015, 01:32 AM Last Post: wepuckett |
| Steering shaft Extension Question??? | Broncitis | 4 | 4,659 |
04-17-2015, 02:27 PM Last Post: Broncitis |
| Quick disconnect steering wheel | snipes243 | 4 | 5,436 |
08-21-2012, 06:50 PM Last Post: snipes243 |
| Power Steering issues | Crawdad | 31 | 13,356 |
07-28-2011, 09:29 PM Last Post: Crawdad |
| Home made heavy duty steering | Timstrk | 4 | 4,195 |
11-25-2010, 10:47 AM Last Post: firefighter2134 |
| power steering pumps | snipes243 | 9 | 7,899 |
11-15-2010, 05:17 PM Last Post: nhopman |
| water pump v8 302 torque spec | jrshepherd | 5 | 5,162 |
11-13-2010, 10:45 PM Last Post: Casey835 |
| v8 water pump question | jrshepherd | 7 | 4,001 |
11-08-2010, 10:18 AM Last Post: broncosbybart |
