Front disk/Rear window
'89 FSB, needs new pads...trying to figure out how to remove the pins that hold the calipers on the front disks...Confusedcratchhe:
Rear window motor runs but the glass don't move...can't even see where the darn thing is (assume it's under those big gear things...regulators??)
New to me...fixing all the little things so I can get it through the NC inspection...
First rig for son (16) so it's a "project truck" :popc1:
302 (got another block with 351W heads available to go in)
Looking at mild lift, 2" body/2" suspension.
Suggestions appreciated. :beer:
see if this helps any with the brakes
http://www.autozone.com/addVehicleId,104...5280181069
Ogeechee 4x4 Wrote:see if this helps any with the brakes
Thanks! :notworthy:
I just haven't figured out how to get the pins out....probably need a bigger hammer :beer:
  1977 Ford Bronco rear ended 9" rebuild Crawdad 10 9,063 01-19-2017, 12:53 PM
  Rebuilding used rear leaf springs Crawdad 5 6,523 12-12-2016, 11:54 AM
  Lighted rear view mirror chuzie 6 7,724 06-20-2015, 12:18 AM
  Front shock mounts snipes243 14 7,397 03-01-2015, 07:51 PM
  rear main seal snipes243 5 5,045 05-03-2014, 11:45 AM
  stock rear drums scbronco 11 5,841 03-06-2014, 08:09 PM
  Late 70s Cadi rear disc brakes for 77 banjo rear end Crawdad 11 7,612 01-11-2014, 12:26 AM
  77 EB Rear Drive Shaft Dropped - Second time in six months UTFLIWGYA 4 4,153 12-01-2013, 10:38 PM
  Grinding sound from rear end area when driving Crawdad 10 7,883 02-09-2013, 09:33 PM
  '94 351 Rear Main replacement JayT 5 3,834 12-22-2012, 05:34 PM
