little black box behind battery in 90 Bronco???
Hi Board,
Can someone tell me what the little black box with cables running to it just behind the battery is?
My bronco wouldn't start today and then I noticed smoke coming from that black box.
Is it the voltage regulator?
Thanks, Clint
Ewwwww!
Please tell me you disconnected the battery and have a fire extinguisher in your Bronco.
If I am not mistaken, were the VRs on those not integrated into the alternator?
Is it the relay box? Can you open it up.
FSB guys, chime in and shed some light.
Hi Chuzie, yes I now know it's the relay box. So what do you suppose is wrong with my bronco? Any ideas?
Thanks, Clint
Well, I just replaced the starter solenoid switch and it's still not starting.
Gives me the buzz sound, and no fire.
What should I try next?
Thanks, Clint
Buzz sound from the dash, from the solenoid, from the starter?
So no cranking? Nothing right? Rather a buch of clicking noise kind of like when your battery is low on voltage?
That sound is the starter relay (solenoid) opening and closing. If you have that sound but no crank I would say you have a battery issue or a starter issue and not something in between. What is your battery voltage? How about the connections both at the battery and the starter?
I would also suggest moving the crank by hand a hair in case it is in a bad spot not allowing the starter to move. Or put it in gear and move it.
I can't beleive no FSB guys will chime in...come on
Lets get this Bronco on the road!!!
Get a pic of it up, the voltage regulator is the big coffee can. There are a lot of black boxes in that area so I need some visual stimulation to help.
You can start by checking all your connections and making sure the new starter solenoid is wired correctly.
1996 Bronco, 302, E4OD -- 1977 F100, 300, C4
Quick update everyone,
I replaced the solenoid and had the same problem so I took it up the road to a mechanic and he discovered a bad starter and burnt out solenoid. She's back on the road and running now.
Thanks for everyone's input.
Clint
  1977 Ford Bronco rear ended 9" rebuild Crawdad 10 9,062 01-19-2017, 12:53 PM
  BC Bronco Soft Top knoxville714 3 5,125 07-12-2016, 08:04 PM
  1996 Bronco New BSD 4" long arm lift on IFS suspension- Setting Wheelbase jrshepherd 11 6,992 01-31-2016, 03:55 PM
  Steering box help snipes243 24 17,780 07-17-2015, 09:42 AM
  Another Bronco Floor Replacement jdowns67 83 32,784 12-20-2014, 11:33 AM
  Mystery Bronco, need your expertise to solve 1st Bronco 2 4,484 08-04-2013, 10:48 PM
Last Post: 1st Bronco
  OK. I love my Bronco again Timstrk 3 4,455 05-19-2013, 08:43 PM
  Bronco Help Around Greenwood Jbass 29 20,165 01-20-2013, 03:16 PM
