my bronco
1972 bronco sport. bought this bronco in december of 06' with no axles. Was a donor truck for a newer jeep! Has sat for about 2 years and finally I went and asked if he would sell. Had seen very few with a body in this kind of shape!! already had power steering set up, shock hoops in front, drop raduis arm brackets, duel shock set-up in rear, shifter moved to floor with duff set-up, ect. I found a guy near greensboro that a front disc d44 with a 3.54 gear and a rear with 4.10 gear. Went completly thru front with new EVERYTHING and ordered a 5.5 inch lift from superlift. Pulled the 302 roller that came in the bronco ( did not run) and built a 302 I had here. .40 over, decked heads, shaved block, cam, timing gears, rollerized rockers, 4 barrel intake, elderbrock carb, HEI distributor, underdrive pullies, ect. Installed power brake set-up. Rhino-lined inside. Had to install inner fenders and wheel wells. Currently running 39.5x15.5x16.5 swampers. Not very practical, but turns alot of heads!! I've had it in a couple of local shows around. Did not take any pics during the build, but have some before and after pics. Still need to do interior and paint dash. Wish I had took my time and did a frame up!!
Nice rig. Hate to see it was a parts rig for a Jeep. Looks like you have turned it around and it looks pretty nice. Way to bring it back from the brink!!!
Yea Cool and nice color too!
[Image: th_drivewayfun.jpg]
[SIGPIC][/SIGPIC]This is what you see, on my 73!
very nice!!!!!
Woody, if your pics are too big to upload to the CB4x4 server I suggest you try photobucket.com.
BTW- I too would have preferred a frame up but was in a hurry to get on the road. Perhaps some time in the future I will calm down and do it the way I want.
Here are some more pics. Thanks for all the compliments! Hope to build one someday from the frame up. When I bought this thing, I said I was going to take my time and do it right, But I got in a hurry and went oppisite of what I wanted to build. Maybe next time!!
That's a good look-n rig......:xyxthumbs:
http://www.wheelindixie.com
it is nice , ive seen it in person.
:beer:Thanks!
Very nice Bronco!
  1977 Ford Bronco rear ended 9" rebuild Crawdad 10 9,062 01-19-2017, 12:53 PM
  BC Bronco Soft Top knoxville714 3 5,125 07-12-2016, 08:04 PM
  1996 Bronco New BSD 4" long arm lift on IFS suspension- Setting Wheelbase jrshepherd 11 6,992 01-31-2016, 03:55 PM
  Another Bronco Floor Replacement jdowns67 83 32,784 12-20-2014, 11:33 AM
  Mystery Bronco, need your expertise to solve 1st Bronco 2 4,484 08-04-2013, 10:48 PM
Last Post: 1st Bronco
  OK. I love my Bronco again Timstrk 3 4,455 05-19-2013, 08:43 PM
  Bronco Help Around Greenwood Jbass 29 20,165 01-20-2013, 03:16 PM
  Bronco techs in/near Raleigh? Mbowles 10 5,695 11-30-2012, 07:07 PM
Last Post: Mbowles
