NEED SOME ADVICE PLEASE
I'll give ya another vote for the C4- STAK B Box 3 speed. the B box is designed to fit in an early Bronco and you can get it in
5.44:1, 3.05:1, 1:1
4.33:1, 2.43:1, 1:1
3.75:1, 2.05:1, 1:1
0.79:1, 4.33:1, 1:1
It's clockable in 4* increments and requires no adapter to mate it to a C4.
I've been thinking about putting a doubler between my Np435 and D20 but this might be a more viable option.
It's alittle pricey but when you compare to an atlas a doubler and built D20 it's really pretty compareable.
66 Rockrawler, 66 RestoMod
[SIGPIC] [/SIGPIC]
THANKS for the vote 66gasgrill.....Wow, a NP435/doubler/D20....now thats getting down and dirty low....nice......What do you think about the 4.33:1, 2.43:1, 1:1 combo for all around wheelin?
Have you heard STAK is coming out with a new three speed designed for the EB!!!!!? It's in testing as we speak and should be available for order in 2 - 4 months....Supposed to be smaller/lighter......Feel free to call Mike Pope with Pope Automotive (904) 724-9455 to ask any questions/order one....Mike is becoming an EB expert in NE Florida and is the new STAK distributor in our area.
Hank
I was told the doubler was around $1500 just for the adapter:rubeyes: Thats a lot of cake to still be rolling with a D20...which should be up graded to a 32spline output shaft also.
I don't have much experience rock/mountain crawling......is there such thing as too low?
At what ratio is the point of no positive return?
the problem with the lower south east...is it will usually be wet somewhere around the obstacle or on the trail. Those are the times...wheel speed is a must. Being able to select 1 low or double low is awesome. Plus if your trail riding with a group...you may fall way behind.
  What to do advice Phoneman 5 3,363 05-14-2014, 05:56 PM
Last Post: Phoneman
  A little advice rancej 5 2,042 03-19-2011, 11:53 PM
Last Post: rancej
  Cam advice.... chuzie 32 12,240 02-01-2011, 07:34 PM
  Need Advice on 351W Headers 73Bronc 9 3,798 10-15-2009, 12:04 PM
Last Post: wormhole
  Need advice on tube flaring problem... chuzie 8 1,991 08-28-2009, 05:42 PM
Last Post: 66stocker
  power steering set up advice ?????? broncomania 6 5,583 04-09-2009, 06:44 PM
  need some parts and advice offshorecorley 1 3,206 12-03-2008, 08:21 PM
Last Post: offshorecorley
  Engine build advice cuz1 6 1,871 06-27-2008, 05:35 PM
  Need some advice johnpaulgolf 31 8,747 05-27-2008, 09:06 PM
