Front wheels jerk when in 4X4-any ideas?
Hi Board,
My new Bronco runs great, only problem seems to be when I engage 4X4 the front wheels jerk and wobble when I turn the steering wheel. It's very noticable - probably jerking the tires several inches each way (left and right) when I turn.
Does anyone know what the problem might be?
Thanks, Clint
Do you know if the front diff. is open or locked? It sounds like a locked up front end.
I'm not sure. How would I know?
Thanks, Clint
cwdanie Wrote:I'm not sure. How would I know?
Thanks, Clint
Jack your front end up. Turn a wheel, if the other turns in the same direction. Its locked. If it turns in the opposite direction. unlockedConfusedupergrin:
General Jon
I also post on another forum and the guys over there are telling me it's completely normal for the front wheels to jerk back and forth w/4X4 b/c I was on pavement.
I used 4X4 to pull a very large boat out of the water on wet pavement with worn tires.
They said there is no problem with my truck, and that I should never use 4X4 on pavement and if you do the tires will wobble very bad when you turn the steering wheel.
Does this sound correct?? I'm really concerned b/c it the wheels were going back and forth like they were having a seizure. ;-)
Thanks for replies,
Clint
Yes, that is right. The front and rear gears are rarely ever the same- exactly. 4.10 in the rear, 4.09 in the front. Close enough in the mud, dirt, snow etc. On pavement there is better traction and one end has to give up the difference. This happens as tire slip in the dirt but not on pavement. Walking back and forth is the trucks effort to equal things out. Low range without locking the front hubs, if thats an option, auto hubs and all, would work to pull the boat.
hope this makes sense,
74 Bronco Ranger halfcab
w/toys
I have 10 years experience in front end alignment service and you guys nailed it. It is perfectly normal on pavement. If it does it anywhere else there might be a problem.:xyxthumbs:
Ditto - 4x4 on pavement or concrete will cause that. Like said above, next time try low gear and don't lock the hubs.
I think you could even have some bad u-joints...they may be frozen up without grease. Just a thought,Chuck
The real issue is that it says F O R D on the front and rear. Smile
  Ideas for hauling a Hi Lift jack? Broncitis 6 2,544 06-19-2015, 05:03 PM
  Front shock mounts snipes243 14 3,942 03-01-2015, 07:51 PM
  Cool Squealing SERP belt!!! Out of ideas chuzie 2 2,602 01-07-2014, 08:32 PM
  new wheels Ron Burgandy 0 1,389 09-16-2012, 05:19 PM
Last Post: Ron Burgandy
  No 4x4 today jdowns67 3 1,155 06-06-2011, 12:59 AM
Last Post: medwards01
  STak 4x4 Monster Transfer Case josephitguy 2 998 01-20-2011, 12:41 PM
  Ideas to Fab a diff guard? chuzie 2 3,148 01-15-2011, 10:59 PM
  Front D44 Ring/Pinion and upgrades scbronco 17 2,933 12-31-2010, 10:07 PM
  Used front hub jdowns67 2 985 10-31-2010, 11:06 AM
  Need Speaker Install Ideas 73Bronc 20 4,848 03-19-2010, 09:00 PM
