Cool Squealing SERP belt!!! Out of ideas
I just got indirectly scolded for posting this on Classic and not here. Sorry. :crying:
351w EFI
Explorer front dress w/ a/c
Running Gates belt K060960 (96-5/8")
She squeals constantly when cold. It reduces in intensity when warm at idle but above idle it is screaming! The belt is relatively new with maybe 1000 miles. It replaced another belt that was doing the same thing.
Soaped the sides: no change
Top : no change
Bottom: jackpot.
Tensioner is tensioning and showing at level 3 of acceptable tension. (1 is tightest)
All pulleys rotate freely with no resistance or grinding when belt removed.
Deflection test between alt and idler (appx 13") yielded about 1/2".
Compared current belt to new belt. Not sure if there should be such a difference here or if this is normal after break-in. New on left, current on right.
[Image: 9u8u7y7a.jpg]
PS pulley has about .035" fore/aft play.
Pulleys look aligned although my peepers ain't what they used to be. Can some confirm?
[Image: aqa6e3y5.jpg]
Gonna clean pulleys and current belt next.
let us know what you find out on the lower crank pulley...im curious
used a Gates belt wear tool and the balancer pulley has the same depth grooves as the stock Ford pulleys so I do not think it is an issue. New belt for now.
  Ideas for hauling a Hi Lift jack? Broncitis 6 4,485 06-19-2015, 05:03 PM
  Ideas to Fab a diff guard? chuzie 2 4,415 01-15-2011, 10:59 PM
  properly mounting a seat belt? chuzie 2 2,365 07-05-2010, 10:31 PM
  Need Speaker Install Ideas 73Bronc 20 9,868 03-19-2010, 09:00 PM
  90 Bronco Timing Belt question cwdanie 5 3,583 01-03-2009, 02:44 AM
Last Post: lobo1117
  Front wheels jerk when in 4X4-any ideas? cwdanie 11 8,036 08-02-2008, 10:43 PM
Last Post: cwdanie
  Ideas for C4 tranny upgrade options chuzie 14 6,996 06-26-2008, 08:38 AM
  ***C4 auto not shifting---need ideas ASAP*** chuzie 2 4,044 06-12-2008, 02:12 PM
  5.0 Serp. Conversion SC74 17 8,049 12-30-2007, 12:18 AM
