new engine
I just got done installing my rebuilt motor and I crankeit and it fired right up good oil pressure nice and smooth but the rocker arms are chattering so i tightend them up but there still making noise. the heads are 351 how do I get them to quiet up.
Turn up the stereo!! On the other hand the rocker nuts should bottom on the studs. Pushrod length may be wrong if that doesn't take all the play out. You can work each one individually by loosening it while the engine is running and then run it back down to the right position. The bolt holes in a 351W head are larger than the bolts for a 302 also. You should have bolt sleeves or have retapped the block for larger bolts. That won't affect the lash but could affect head to block alignment.
[Image: 2rwp56f.png]
berg bronco Wrote:I just got done installing my rebuilt motor and I crankeit and it fired right up good oil pressure nice and smooth but the rocker arms are chattering so i tightend them up but there still making noise. the heads are 351 how do I get them to quiet up.
:wav::gunshot: WE WANT PICTURES JOSH......
The rocker arms are making noise?
I'm guessing you have hydraulic lifters and good oil pressure should pump them up.
Are you sure you have the correct length push rods for those heads?
With hydraulic lifters you should have no play in your valve train.
I find it unusual that you have noise. Keep an eye on it.
sometimes new motors do funny things until everything finds a happy place.
the nuts are botttoming out on all of them but only 7 of them are tight the rest have about .25 inch play the motor already had the 351 heads and pushrods on it when I got it. so I just assumed they where right. pics are coming.
the problem was the pushrods they were just a little to short I got some that were right and it is running perfect!
[Image: DSCN1557640x480.jpg]
[Image: DSCN1558640x480.jpg]
[Image: DSCN1561640x480.jpg]
glad you got it worked out. pics look great.
were you picking the pushrods up yesterday ?
glad to meet you again. I'll probably get a buddy of mines trailer. smaller than my dad's.
thanks for the top!!
shon
I think my rust is rusting...
I got the pushrods out of my old engine they were 1/8 inch longer. nice to meet you yesterday
  Automatic Trans: Why does the engine die as soon as I put it in Park or Neutral???? UTFLIWGYA 6 3,955 05-15-2014, 11:50 AM
Last Post: rbodine
  Engine help snipes243 12 3,334 02-21-2014, 12:06 AM
  Can firing order determine engine block size? 1st Bronco 1 785 08-16-2013, 06:26 PM
  5.0/nv3550...engine now dies at stops*help* blazinchuck 14 3,482 06-09-2013, 10:50 AM
  1996 5.8 L Engine Rebuild- Cylinder heads jrshepherd 0 2,581 07-17-2011, 11:13 AM
Last Post: jrshepherd
  Engine Rebuild. 1996 5.8 L jrshepherd 0 981 05-05-2011, 02:02 AM
  Engine build advice cuz1 6 1,552 06-27-2008, 05:35 PM
  engine taching a bit high? bowtieman55 12 3,686 04-01-2008, 08:05 PM
