09-27-2009, 10:15 PM
So I took my wife out this afternoon in the Bronco to the Grocery store and when I came back out to start the Bronco it went rrrrrrrrrrrrrr then click click then nothing... So I try to role it down the hill and nothing. Then I try the second time to start it and it started right up? When I was at the house it ack like it didn't want to crank.
When I got home it shut off when I pull in the drive way at my house. Then when I try to start it it rrrrrrrr,click click, then nothing.... So I went to put the charger on it but it showed fully charged and the battery started spiting out water out of the top where you fill it with water. Then I try to jump it off and When I put the jumper cables on it spark like hell.. I could have welded with that spark.... I then put a volt meter on it and turn it to DCV 20 and it only showed the Battery to have .09 to .10. So I pull the Battery out of the Bronco. I tested the battery just a sec ago and it showed 11.90? So is the battery bad or does it go bad when it gets hot?
cratchhe:
cratchhe:
cratchhe:
cratchhe: Or is it my Battery? Help me out please. I need to fix it by this weekend.
![Confused Confused](https://cb4x4.com/images/smilies/confused.png)
